I have set up a v5 instance of InvoiceNinja on Docker using docker-compose.
When I am trying to do the migration via the v4 UI I am getting the following error:
Looks like something went wrong with the migration for the following company: XXXX
Resource invoice/quote document not available.
Can someone help me what this means? I was looking at the laravel*.logs but I could not find anything.
Thanks. I have started another migration and tailed -f the stacktrace.log and the laravel-error.log. Unfortunately I did not get any new entry. Any other option to debug this more without looking at the source code? Or is there anything else I can provide you so that you can give me some pointers?
I do not see anything on the UI though. How can I solve this?
I have restarted the docker to make sure this is not a caching issue, but the issue is not fixed with this.
Do I need to update the data manually in some shape or form? (E.g. assign it to a company or so?)
After startng another migration it seem that on the database everything looks good: New company, all invoices linked to the company, users are linked to the company.
Unfortuntely I am now running into a timeout issue when logging in:
TimeoutException after 0:00:30.000000: Future not completed
Sometimes I am also getting a XMLHttpRequest error.
In the logs I am seeing a warning:
2021/08/10 20:31:17 [warn] 24#24: *78 an upstream response is buffered to a temporary file /var/cache/nginx/fastcgi_temp/8/00/0000000008 while reading upstream, client: 192.168.x.x, server: _, request: “POST /api/v1/login?first_load=true&include_static=true HTTP/1.1”, upstream: “fastcgi://172.22.0.3:9000”, host: “192.168.x.x:xx”, referrer: “https://ninja.xxx.xx/”
192.168.2.4 - - [10/Aug/2021:20:31:17 +0000] “POST /api/v1/login?first_load=true&include_static=true HTTP/1.1” 200 548790 “https://ninja.xxx.xx/” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/92.0.4515.131 Safari/537.36” “195.76.177.125”
Any idea why I am suddenly running into a timeout? Migrated data is roughly 2k invoices.
If it is very large, you may need to set the column is_large to 1 so that the front end chunks the data rather than attempting to load it all in one go.
Nevermind, I found it. It is in the companies table: UPDATE companiesSETis_large= '1' WHEREcompanies.id = 1;
This worked, thanks a lot. I can see the new company now and also see the data.
Here are few findings from my side:
If the company you are migrating has the same name as a company that already exists, it did not work for me => I then changed the name of the initial company to something different
Change the is_large to 1 in the companies table (Thanks @david)
Logout and Login after the migration. A simple refresh does not show the data
Thanks for the input @david
I am running this on a local machine, no shared hosting (8GB ram, 2GHz CPU, 2 cores). CUP and RAM usage is not very high though.
I think we are spread out now over 2 threads. Am i correct to say that this issue is resolved, and now the focus is on the migrated custom_fields being the issue?
