I setup and had working the recurring invoices for my customers in my cpanel/softoculus installation. After upgrading to 4.5.46, the invoice is not automatically generated. I did verify there is a cron job for each of the following, paths differ, but I believe to be correct.
0 8 * * * /usr/local/bin/php /path/to/ninja/artisan ninja:send-invoices
0 8 * * * /usr/local/bin/php /path/to/ninja/artisan ninja:send-reminders
I am not seeing any errors in /storage/logs about the cron or other errors.
Thank you for pointer. Makes sense. I was able to implement that cron in which I did get an error. There error is
“Fatal error: Composer detected issues in your platform: Your Composer dependencies require a PHP version “>= 7.3.0”. You are running 7.1.33. in /home/xyxyxyxyxyxyx/public_html/invoices/vendor/composer/platform_check.php on line 24”
When I go to my cpanel under multiphp manager, I am showing php version 7.3 was installed prior to the upgrade. I did go ahead and try to move to php7.4. I am no longer getting that error, but my log file does not show anything else going into it either.
I checked to see if the recurring invoice has been created, and it has not. Any further suggestions would be appreciated.
So doing some more digging, the cpanel cron call had a php version number in it. After doing the move to php7.4 I had to edit the cron from /opt/cpanel/ea-php71/root/usr/bin/php to /opt/cpanel/ea-php74/root/usr/bin/php. Here is the new error below:
Warning: Class ‘Google_Service’ not found in /home/xxxxxxxx/public_html/invoices/vendor/google/apiclient-services/autoload.php on line 21
Warning: Class ‘Google_Service_Resource’ not found in /home/xxxxxxxx/public_html/invoices/vendor/google/apiclient-services/autoload.php on line 21
Warning: Class ‘Google_Model’ not found in /home/xxxxxxx/public_html/invoices/vendor/google/apiclient-services/autoload.php on line 21
Warning: Class ‘Google_Collection’ not found in /home/xxxxxxxx/public_html/invoices/vendor/google/apiclient-services/autoload.php on line 21
Wed, 08 Dec 2021 04:30:04 +0000 Running SendRecurringInvoWed, 08 Wed, 08 Dec 2021 04:30:04 +0000 Recurring invoice(s) found
Wed, 08 Dec 2021 04:30:04 +0000 Processing Invoice: 61
Wed, 08 Dec 2021 04:30:05 +0000 Not billed - Sending Invoice
Wed, 08 Dec 2021 04:30:07 +0000 0 recurring expenses(s) found
Wed, 08 Dec 2021 04:30:07 +0000 Done
4:30:04 +0000 Done
Do you know if those are needed? The invoice was created, now I am waiting to see if the payment is automatically applied. I am not seeing them. Does that have anything to do with the errors included with this message?
