Using projects with invoices - select only from client projects
Hi there,
its either a howto question or a feature request:
When I use projects, where I connect invoice to, it allows me to select from all available projects. But it complains, when the project is not assigned to the client.
It would be helpful, if I could only select from projects assigned to this client. Is this an existing or missing function?
Assuming you’re using the web app feel free to create an issue here to request the change:
You may also want to compare with the desktop app.
