Hi.
I want to give options for users to create quotes invoices and clients, but I would not like them to see the dashboard with all numbers and other Activity info.
Is there an option to hide it?
Thank you
Br,
Dali
Hi.
Thank you
Br,
Dali
You should be able to accomplish this with our latest version by changing the user’s permissions.
Dear Hillel.
Thank you
I have just updated to v2.5.2. Dashboard for user is now empty, except Outstanding number is still there. Don’t know why?
User has only this permissions checked.
Create clients, invoices, etc.
Allow user to create and modify records
Thank you
Br,
Dali
That sounds like a bug, we’ll look into correcting it in our next release.
Great.
Also as on the subject…
How would I give users access to see all the clients, but not other users quotes and requests?
Thank you
Br,
Dali
It’s not supported.
Thank you for reply.
I would like my workers to make quotes,invoices,payments,add/edit clients, but at the same time I would not like them to see entire company accounting, my and other users stuff. I do assign a jobs from the same client to different users. So if they each add the same client there will be many duplicates in admin view.
I believe separating current option in two would make sense.
View all invoices, etc.
Allow user to view records they didn’t create
View all clients
Allow user to view clients they didn’t create
Thank you
Br,
Dali
Thanks for the suggestion, we’ll keep it in mind for a future release.
Thank you Hillel.
I’m sure others will use the feature too.
I really appreciate it!
Br,
Dali
Hi.
I have just downloaded latest version. v2.5.2.2
users with only one option active (Create clients, invoices, etc., Allow user to create and modify records)
Br,
Dali
Thanks for the feedback!
Hi Hillel.
For quotes, user can see other clients but it brakes on save quote for those.
1/1 ErrorException in InvoiceRepository.php line 220: Undefined index: client_id in InvoiceRepository.php line 220 at HandleExceptions->handleError( .... it continues for few pages that I won't paste here. You can try it for yourself. It will brake.
For invoices user will not see other clients but his own.
Thank you
Br,
Dali
Which permissions does the user have?
Hi Hillel.
Br,
Dali
Thanks for the info, I’m looking into it now.
I’ve checked in a fix, it will be included with our next release.
https://github.com/invoiceninja/invoiceninja/commit/26b0169ae91dafe831e81d4cd3c9c0331e36c728
Hi Hillel.
I have updated EntityModel.php and QuoteController.php.
Now the user can only see the clients he created. Not others. So how can a new user create a quote to a client that he didn’t create?
Thank you
Br,
Dali
You can set the ‘View all …’ permission to enable users to see records they didn’t create.
We don’t support showing all clients but not all invoices, we may add it in a future release.
Thank you
I would really like that feature.
Br,
Dali
