Hi there,
IIf I am not wrong, you cannot setup an invoice design for recurring invoices, since you have to assign a number.
I use RE-{$date:ym}-{$counter} right now and the system telss me, that this number has already been taken, since I have more than 10 rcurring invoices, which all have the same number.
The error message while trying to save the recurring invoice is
422: The given data was invalid.
• The number has already been taken.
Hi Hilklel,
thanks for your fast reply.
I have prepared some recurring invoices that will be used toomorrow. I have chosen a client, some items and so on. When I try to edit the recurring invoice it asks me to type in an invoice number,
When I use RE-{$date:ym}-{$counter} for the invoice number it ist possible only for the first recurring invoice. If i use the same number format in another recurring invoice, I receive the error message
Do you want to use the RE-{$date:ym}-{$counter} for recurring invoices or for the standard invoices which are created by the recurring invoice?
It sounds like you may have set the custom RE-{$date:ym}-{$counter} pattern for the recurring invoice settings whereas you should set it for the invoice setting.
