is there a possibility to upload a document from the mobile web page? I would like to add an expense but can’t upload the document
edit: App is the same
This is supported in the mobile app, is it not working for you?
I don’t see an option?
When viewing an expense you should see a “Documents” tab.
Ok the workflow is different
Create an expense → View the expense → Documents
