Because I want to upgrade, I open account management/migrate then click on start migrate which directs to https://DOMAIN/migration/start and naturally I just get plain Url not found there since there is nothing there and that is not an IN path.
I can manually rewrite the url to https://DOMAIN/invoiceninja/public/migration/start in the url bar and it works but just for that page, the next step it still redirects me to https://DOMAIN/migration/type
What are my options for properly migrating given I will still need to use v5 under a subpath.
To upgrade from v4 you need to install v5 as a separate app and then use the migration tool in the latest version of v4 on Settings > Account Management.
Still that is not the issue. Maybe I did not articulate it well. This is not a version or migration method issue.
I am using subfolder on my server https://DOMAIN/invoiceninja. Invoiceninja migration tool seems to want to be served from the domain’s root. So the migration tool points to a non existing path once started, see my first post for the details.
This is the previous comment which caught my eye. If you have to manually insert /public either you have a rewrite issue, or your .env file does not contain /public in the URL.
I upgraded to to 4.5.42 and the issue went away interestingly.
However I am hitting a new issue with installing V5. I am installing it under Apache and under a subpath.
I go through all the steps, all look good but when I click on submit in the end I just get a 404 instead of finishing the installation fully (I assume it would direct me to the login page). I see that it creates a new .env and it fills it properly.
The only error I can find is this in laravel.log Not sure if it matters at this point. There are not much else in the document.
There is also no error in the browser console beside that 404. I am not able to get clue on this.
[2021-07-03 04:57:11] production.INFO: db fails
[2021-07-03 04:57:30] production.ERROR: CURL Error #60: SSL: no alternative certificate subject name matches target host name 'phantomjscloud.com'
[2021-07-03 04:58:51] production.INFO: latest version = 5.2.7
Hi
So is there a manual way of upgrading from 4 to 5? I would love to upgrade and enjoy the new provided features, I am just stuck due to url rewiritng or whatever the underlying issue is.
