Hi all,
I am trying to upgrade from version 5.3.96 to 5.3.100 via docker, but after updating its stuck.
Docker complains and get stuck at
“SQLSTATE[42S01]: Base table or view already exists: 1050 Table ‘purchase_order_invitations’ already exists”
Any suggestions?
david
3
@bitfinity
I haven’t been able to recreate this from my tests, is it possible you have tried to restore from a different version at some stage?
@david, nope this was the first upgrade. My initial install version is 5.3.96.
david
5
@bitfinity
To get past this issue, you’ll need to update a field in the database,
In the migrations table, find the row:
2022_06_01_224339_create_purchase_order_invitations_table
and you’ll want to update the batch number to the same value as
2022_06_01_215859_set_recurring_client_timestamp
I’ll try tonight, thanks for the response
Finally got the time to further investigate it and came up with a solution.
First I “2022_06_01_224339_create_purchase_order_invitations_table” with the value “2” to the table migration.
After running “docker compose up” I got another error which i solved also with adding the following row to the table migrations.
“2022_07_09_235510_add_index_to_payment_hash” with value “2”
Now I have upgraded to version 5.5.2-L88
