So I installed a fresh docker using the latest invoiceninja/invoiceninja, but i’m greeted with an 502 Bad Gateway error, i’m not getting to the setup page. I have an nginx server running which is using proxy_pass to the dockerserver with invoiceninja installed. I also already setup trusted_proxies in my env variables
Logs:
InvoiceNinja docker log:
2021-11-04T09:32:57Z [INFO] [Entrypoint]: Initialising Invoice Ninja...
Configuration cache cleared!
Configuration cached successfully!
Route cache cleared!
Routes cached successfully!
Files cached successfully!
Nothing to migrate.
2021-11-04 09:32:59,584 WARN For [program:php-fpm], redirect_stderr=true but stderr_logfile has also been set to a filename, the filename has been ignored
2021-11-04 09:32:59,584 WARN For [program:scheduler], redirect_stderr=true but stderr_logfile has also been set to a filename, the filename has been ignored
2021-11-04 09:32:59,584 WARN For [program:queue-worker], redirect_stderr=true but stderr_logfile has also been set to a filename, the filename has been ignored
2021-11-04 09:32:59,586 INFO supervisord started with pid 1
2021-11-04 09:33:00,589 INFO spawned: 'shutdown' with pid 76
2021-11-04 09:33:00,591 INFO spawned: 'php-fpm' with pid 77
2021-11-04 09:33:00,594 INFO spawned: 'queue-worker_00' with pid 78
2021-11-04 09:33:00,596 INFO spawned: 'queue-worker_01' with pid 79
2021-11-04 09:33:00,598 INFO spawned: 'scheduler' with pid 80
READY
[04-Nov-2021 09:33:00] NOTICE: [pool www] 'user' directive is ignored when FPM is not running as root
[04-Nov-2021 09:33:00] NOTICE: [pool www] 'group' directive is ignored when FPM is not running as root
[04-Nov-2021 09:33:00] NOTICE: fpm is running, pid 77
[04-Nov-2021 09:33:00] NOTICE: ready to handle connections
Schedule worker started successfully.
2021-11-04 09:33:01,935 INFO success: shutdown entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2021-11-04 09:33:01,935 INFO success: php-fpm entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2021-11-04 09:33:01,936 INFO success: queue-worker_00 entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2021-11-04 09:33:01,936 INFO success: queue-worker_01 entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2021-11-04 09:33:01,936 INFO success: scheduler entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
[2021-11-04T09:34:00+00:00] Execution #1 output:
No scheduled commands are ready to run.
[2021-11-04T09:35:00+00:00] Execution #2 output:
[2021-11-04T09:35:00+00:00] Running scheduled command: Callback
[2021-11-04T09:36:00+00:00] Execution #3 output:
[2021-11-04T09:37:00+00:00] Execution #4 output:
[2021-11-04T09:38:00+00:00] Execution #5 output:
[2021-11-04T09:39:00+00:00] Execution #6 output:
[2021-11-04T09:40:00+00:00] Execution #7 output:
[2021-11-04T09:40:00+00:00] Running scheduled command: Callback
[2021-11-04T09:41:00+00:00] Execution #8 output:
[2021-11-04T09:42:00+00:00] Execution #9 output:
[2021-11-04T09:43:00+00:00] Execution #10 output:
[2021-11-04T09:44:00+00:00] Execution #11 output:
[2021-11-04T09:45:00+00:00] Execution #12 output:
[2021-11-04T09:45:00+00:00] Running scheduled command: Callback
[2021-11-04T09:46:00+00:00] Execution #13 output:
There are no log files in my storage or public folders, there are no files at all in those folders.
My nginx config:
#INVOICENINJA CONTAINER
server {
listen 80;
server_name invoice.mydomain.nl;
return 301 https://$server_name$request_uri;
server {
listen 443 ssl http2;
#SSL settings
include /config/nginx/ssl.conf;
#Maxmind geoblock
#include /config/nginx/geoblock.conf;
location / {
proxy_pass http://10.0.0.104:8001;
proxy_set_header Host $host;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
Do you have any idea what i’m doing wrong?
