I just upgraded to 3.8.1 and my invoices are all there. But when I open one it is blank…no details. Also, if I visit my site in incognito mode it lists the directory contents. you can see it at https://spartan-it.com/invoices
All I did to update was to unzip the update file into the directory and launch the site. It said the database was successfully updated and all looked well.
Yes I am. When I go to my site in my normal browser window it loads with no problem (except for the blank invoices) so I’m guessing that has to do with caching. But when I try incognito or IE it does a directory listing. I added a line to the .htaccess to hide the directory listing so now it doesn’t show the files…but it still doesn’t load the site.
Another nugget of info. When I uncomment that line I get redirected to my main site’s wp-login.php page. Invoice Ninja is in the invoices directory beneath my main site.
Not that I recall. I’m downloading my backup now so I can see my old htaccess file to see what I’m missing. As far as the blank invoices…I have no idea. If I can’t correct it, I’ll just have to restore my backup and stay on the older version.
Thanks for mentioning the changes…that made me look at the backup file and I found the issue with the directory listing.
There was a mod_alias RedirectMatch in the original htaccess. I placed that back in and it works great. Still have the issue of the blank invoices. My guess is it’s a similar issue with a missing configuration…still looking.
