Version v5.10.40
Environment Shared Hosting
Checklist
- Can you replicate the issue on our v5 demo site https://demo.invoiceninja.com or Invoice Ninja? NO
- Have you searched existing issues? YES
- Have you inspected the logs in storage/logs/laravel.log for any errors? YES
Describe the bug
When updating via Softaculous, it had asked to update PHP version to 8.2 or above. It then listed PHP Extensions that was required. These were enabled and allowed me to continue the update.
After the update, I was presented with the Setup screen asking for the database and user details.
As this was an update, it shouldnât need it. The database and .env file was still intact with the previous version configuration.
I discovered one of the PHP Extensions were missing from the update script ârequired extensionsâ â php_mysql
After enabling this, everything worked fine.
Additional context
During update to 5.10, one of the PHP Extensions that was required wasnât checked against and listed before proceeding with the update (pdo_mysql).
Logs
[2024-11-21 11:05:41] production.ERROR: could not find driver (Connection: mysql, SQL: select * from client_contacts
where id
= 42 and client_contacts
.deleted_at
is null limit 1) {âexceptionâ:"[object] (Illuminate\Database\QueryException(code: 0): could not find driver (Connection: mysql, SQL: select * from client_contacts
where id
.deleted_at
is null limit 1) at /home/public/ninja.***.com/vendor/laravel/framework/src/Illuminate/Database/Connection.php:825)
[previous exception] [object] (PDOException(code: 0): could not find driver at /home/public/ninja.***.com/vendor/laravel/framework/src/Illuminate/Database/Connectors/Connector.php:66)
