I have Invoice Ninja via Softaculous on my domain. When I update to 3.0.5, I receive a lot of MySQL database errors. What can I do to fix it?
I tried adding the columns myself, but was unsure of the structure. After adding the posted one below, a few others came through as not found.
QueryException in Connection.php line 729:
SQLSTATE[42S22]: Column not found: 1054 Unknown column 'invoices.is_public' in 'where clause' (SQL: select COUNT(DISTINCT CASE WHEN <code>invoices</code>.<code>id</code> IS NOT NULL THEN <code>clients</code>.<code>id</code> ELSE null END) billed_clients,
SUM(CASE WHEN <code>invoices</code>.<code>invoice_status_id</code> >= 2 THEN 1 ELSE 0 END) invoices_sent,
COUNT(DISTINCT <code>clients</code>.<code>id</code>) active_clients from <code>accounts</code> left join <code>clients</code> on <code>accounts</code>.<code>id</code> = <code>clients</code>.<code>account_id</code> left join <code>invoices</code> on <code>clients</code>.<code>id</code> = <code>invoices</code>.<code>client_id</code> where <code>accounts</code>.<code>id</code> = 1 and <code>clients</code>.<code>is_deleted</code> = 0 and <code>invoices</code>.<code>is_deleted</code> = 0 and <code>invoices</code>.<code>is_recurring</code> = 0 and <code>invoices</code>.<code>is_public</code> = 1 and <code>invoices</code>.<code>invoice_type_id</code> = 1 group by <code>accounts</code>.<code>id</code> limit 1)
at Connection->runQueryCallback('select COUNT(DISTINCT CASE WHEN <code>invoices</code>.<code>id</code> IS NOT NULL THEN <code>clients</code>.<code>id</code> ELSE null END) billed_clients, SUM(CASE WHEN <code>invoices</code>.<code>invoice_status_id</code> >= 2 THEN 1 ELSE 0 END) invoices_sent, COUNT(DISTINCT <code>clients</code>.<code>id</code>) active_clients from <code>accounts</code> left join <code>clients</code> on <code>accounts</code>.<code>id</code> = <code>clients</code>.<code>account_id</code> left join <code>invoices</code> on <code>clients</code>.<code>id</code> = <code>invoices</code>.<code>client_id</code> where <code>accounts</code>.<code>id</code> = ? and <code>clients</code>.<code>is_deleted</code> = ? and <code>invoices</code>.<code>is_deleted</code> = ? and <code>invoices</code>.<code>is_recurring</code> = ? and <code>invoices</code>.<code>is_public</code> = ? and <code>invoices</code>.<code>invoice_type_id</code> = ? group by <code>accounts</code>.<code>id</code> limit 1', array('1', false, false, false, true, '1'), object(Closure)) in Connection.php line 685
at Connection->run('select COUNT(DISTINCT CASE WHEN <code>invoices</code>.<code>id</code> IS NOT NULL THEN <code>clients</code>.<code>id</code> ELSE null END) billed_clients, SUM(CASE WHEN <code>invoices</code>.<code>invoice_status_id</code> >= 2 THEN 1 ELSE 0 END) invoices_sent, COUNT(DISTINCT <code>clients</code>.<code>id</code>) active_clients from <code>accounts</code> left join <code>clients</code> on <code>accounts</code>.<code>id</code> = <code>clients</code>.<code>account_id</code> left join <code>invoices</code> on <code>clients</code>.<code>id</code> = <code>invoices</code>.<code>client_id</code> where <code>accounts</code>.<code>id</code> = ? and <code>clients</code>.<code>is_deleted</code> = ? and <code>invoices</code>.<code>is_deleted</code> = ? and <code>invoices</code>.<code>is_recurring</code> = ? and <code>invoices</code>.<code>is_public</code> = ? and <code>invoices</code>.<code>invoice_type_id</code> = ? group by <code>accounts</code>.<code>id</code> limit 1', array('1', false, false, false, true, '1'), object(Closure)) in Connection.php line 349
at Connection->select('select COUNT(DISTINCT CASE WHEN <code>invoices</code>.<code>id</code> IS NOT NULL THEN <code>clients</code>.<code>id</code> ELSE null END) billed_clients, SUM(CASE WHEN <code>invoices</code>.<code>invoice_status_id</code> >= 2 THEN 1 ELSE 0 END) invoices_sent, COUNT(DISTINCT <code>clients</code>.<code>id</code>) active_clients from <code>accounts</code> left join <code>clients</code> on <code>accounts</code>.<code>id</code> = <code>clients</code>.<code>account_id</code> left join <code>invoices</code> on <code>clients</code>.<code>id</code> = <code>invoices</code>.<code>client_id</code> where <code>accounts</code>.<code>id</code> = ? and <code>clients</code>.<code>is_deleted</code> = ? and <code>invoices</code>.<code>is_deleted</code> = ? and <code>invoices</code>.<code>is_recurring</code> = ? and <code>invoices</code>.<code>is_public</code> = ? and <code>invoices</code>.<code>invoice_type_id</code> = ? group by <code>accounts</code>.<code>id</code> limit 1', array('1', false, false, false, true, '1'), true) in Builder.php line 1610
at Builder->runSelect() in Builder.php line 1596
at Builder->get(array('*')) in Builder.php line 1577
at Builder->first() in DashboardRepository.php line 183
at DashboardRepository->totals('1', '1', true) in DashboardController.php line 35
at DashboardController->index()
at call_user_func_array(array(object(DashboardController), 'index'), array()) in compiled.php line 9482
at Controller->callAction('index', array()) in compiled.php line 9544
at ControllerDispatcher->call(object(DashboardController), object(Route), 'index') in compiled.php line 9524
at ControllerDispatcher->Illuminate\Routing\{closure}(object(Request))
at call_user_func(object(Closure), object(Request)) in Pipeline.php line 52
at Pipeline->Illuminate\Routing\{closure}(object(Request))
at call_user_func(object(Closure), object(Request)) in compiled.php line 10006
at Pipeline->then(object(Closure)) in compiled.php line 9525
at ControllerDispatcher->callWithinStack(object(DashboardController), object(Route), object(Request), 'index') in compiled.php line 9512
at ControllerDispatcher->dispatch(object(Route), object(Request), 'App\Http\Controllers\DashboardController', 'index') in compiled.php line 8582
at Route->runController(object(Request)) in compiled.php line 8569
at Route->run(object(Request)) in compiled.php line 8283
at Router->Illuminate\Routing\{closure}(object(Request))
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in Authenticate.php line 90
at Authenticate->handle(object(Request), object(Closure), 'user')
at call_user_func_array(array(object(Authenticate), 'handle'), array(object(Request), object(Closure), 'user')) in compiled.php line 10021
at Pipeline->Illuminate\Pipeline\{closure}(object(Request))
at call_user_func(object(Closure), object(Request)) in Pipeline.php line 32
at Pipeline->then(object(Closure)) in compiled.php line 8284
at Router->runRouteWithinStack(object(Route), object(Request)) in compiled.php line 8275
at Router->dispatchToRoute(object(Request)) in compiled.php line 8265
at Router->dispatch(object(Request)) in compiled.php line 2419
at Kernel->Illuminate\Foundation\Http\{closure}(object(Request))
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in Debugbar.php line 51
at Debugbar->handle(object(Request), object(Closure))
at call_user_func_array(array(object(Debugbar), 'handle'), array(object(Request), object(Closure))) in compiled.php line 10021
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in StartupCheck.php line 197
at StartupCheck->handle(object(Request), object(Closure))
at call_user_func_array(array(object(StartupCheck), 'handle'), array(object(Request), object(Closure))) in compiled.php line 10021
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in QueryLogging.php line 29
at QueryLogging->handle(object(Request), object(Closure))
at call_user_func_array(array(object(QueryLogging), 'handle'), array(object(Request), object(Closure))) in compiled.php line 10021
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in DuplicateSubmissionCheck.php line 36
at DuplicateSubmissionCheck->handle(object(Request), object(Closure))
at call_user_func_array(array(object(DuplicateSubmissionCheck), 'handle'), array(object(Request), object(Closure))) in compiled.php line 10021
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in compiled.php line 3225
at VerifyCsrfToken->handle(object(Request), object(Closure)) in VerifyCsrfToken.php line 42
at call_user_func_array(array(object(VerifyCsrfToken), 'handle'), array(object(Request), object(Closure))) in compiled.php line 10021
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in compiled.php line 13532
at ShareErrorsFromSession->handle(object(Request), object(Closure))
at call_user_func_array(array(object(ShareErrorsFromSession), 'handle'), array(object(Request), object(Closure))) in compiled.php line 10021
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in compiled.php line 12022
at StartSession->handle(object(Request), object(Closure))
at call_user_func_array(array(object(StartSession), 'handle'), array(object(Request), object(Closure))) in compiled.php line 10021
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in compiled.php line 13271
at AddQueuedCookiesToResponse->handle(object(Request), object(Closure))
at call_user_func_array(array(object(AddQueuedCookiesToResponse), 'handle'), array(object(Request), object(Closure))) in compiled.php line 10021
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in compiled.php line 13208
at EncryptCookies->handle(object(Request), object(Closure))
at call_user_func_array(array(object(EncryptCookies), 'handle'), array(object(Request), object(Closure))) in compiled.php line 10021
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in compiled.php line 3286
at CheckForMaintenanceMode->handle(object(Request), object(Closure))
at call_user_func_array(array(object(CheckForMaintenanceMode), 'handle'), array(object(Request), object(Closure))) in compiled.php line 10021
at Pipeline->then(object(Closure)) in compiled.php line 2366
at Kernel->sendRequestThroughRouter(object(Request)) in compiled.php line 2350
at Kernel->handle(object(Request)) in index.php line 52
PDOException in Connection.php line 333:
at PDO->prepare('select COUNT(DISTINCT CASE WHEN <code>invoices</code>.<code>id</code> IS NOT NULL THEN <code>clients</code>.<code>id</code> ELSE null END) billed_clients, SUM(CASE WHEN <code>invoices</code>.<code>invoice_status_id</code> >= 2 THEN 1 ELSE 0 END) invoices_sent, COUNT(DISTINCT <code>clients</code>.<code>id</code>) active_clients from <code>accounts</code> left join <code>clients</code> on <code>accounts</code>.<code>id</code> = <code>clients</code>.<code>account_id</code> left join <code>invoices</code> on <code>clients</code>.<code>id</code> = <code>invoices</code>.<code>client_id</code> where <code>accounts</code>.<code>id</code> = ? and <code>clients</code>.<code>is_deleted</code> = ? and <code>invoices</code>.<code>is_deleted</code> = ? and <code>invoices</code>.<code>is_recurring</code> = ? and <code>invoices</code>.<code>is_public</code> = ? and <code>invoices</code>.<code>invoice_type_id</code> = ? group by <code>accounts</code>.<code>id</code> limit 1') in Connection.php line 333
at Connection->Illuminate\Database\{closure}(object(MySqlConnection), 'select COUNT(DISTINCT CASE WHEN <code>invoices</code>.<code>id</code> IS NOT NULL THEN <code>clients</code>.<code>id</code> ELSE null END) billed_clients, SUM(CASE WHEN <code>invoices</code>.<code>invoice_status_id</code> >= 2 THEN 1 ELSE 0 END) invoices_sent, COUNT(DISTINCT <code>clients</code>.<code>id</code>) active_clients from <code>accounts</code> left join <code>clients</code> on <code>accounts</code>.<code>id</code> = <code>clients</code>.<code>account_id</code> left join <code>invoices</code> on <code>clients</code>.<code>id</code> = <code>invoices</code>.<code>client_id</code> where <code>accounts</code>.<code>id</code> = ? and <code>clients</code>.<code>is_deleted</code> = ? and <code>invoices</code>.<code>is_deleted</code> = ? and <code>invoices</code>.<code>is_recurring</code> = ? and <code>invoices</code>.<code>is_public</code> = ? and <code>invoices</code>.<code>invoice_type_id</code> = ? group by <code>accounts</code>.<code>id</code> limit 1', array('1', false, false, false, true, '1')) in Connection.php line 722
