Hi all,
I want to update my Invoiceninja installation. I pull from github the latest changes, then I ran ninja:post-update but I received an error as follow:
silvia@zago:~/invoiceninja5/dockerfiles$ docker-compose exec app php artisan ninja:post-update
The “–no-dev:” option does not exist.
install [–prefer-source] [–prefer-dist] [–dry-run] [–dev] [–no-suggest] [–no-dev] [–no-autoloader] [–no-scripts] [–no-progress] [–no-install] [-v|vv|vvv|–verbose] [-o|–optimize-autoloader] [-a|–classmap-authoritative] [–apcu-autoloader] [–apcu-autoloader-prefix APCU-AUTOLOADER-PREFIX] [–ignore-platform-req IGNORE-PLATFORM-REQ] [–ignore-platform-reqs] [–] […]
How I can update to latest release?
Thank you
Silvia
david
March 14, 2021, 8:50pm
docker-compose down
docker-compose pull
docker-compose up
Will not that action remove volumes too?
david
July 6, 2023, 12:07am
4
@nacesprin
nope, it only updates the container
Only to confirm:
Does It update the container and keep current volume with no data loss?
Yes, all volumes are kept with no data loss
david:
docker-compose down
Stops containers managed by the docker-compose.yml
file and removes them. Removing containers does not remove persisted data which were mounted into the contianers via bind mounts or volumes.
david:
docker-compose pull
Pulls all images defined in docker-compose.yml
file if there are newer versions on the registry server. You can pull images with a specific tag if you want to.
Example:
version: "3"
services:
invoiceninja:
image: invoiceninja/invoiceninja:latest
This will always pull the latest (newest) docker image for invoiceninja
version: "3"
services:
invoiceninja:
image: invoiceninja/invoiceninja:5.5
This will pull the latest docker image for invoiceninja
v5.5.x, but not 5.6.x or newer.
david:
docker-compose up
Starts containers managed by the docker-compose.yml
file. I’d recommend starting them with the option --detach
or -d
to start them in the background.
My prefered solution for updating IN is this little oneliner:
docker compose pull -q; [[ $(grep -q '<none>'< <(docker compose images)) ]] && docker compose up -d --force-recreate;
This command pulls new images and if they were updated, it recreates the containers. This reduces the “downtime” to the minimum and recreates the containers only if necessary.
Best regards
@Access-InTech
Btw:
@hillel
accessintech@svrs:~$ docker-compose --version
docker-compose version 1.29.2, build 5becea4c
accessintech@svrs:~$ docker compose version
Docker Compose version v2.18.1
You should consider updating the update hint to Docker Compose V2 (docker compose
instead of docker-compose
July 25, 2023, 8:42pm
9
Thanks for the suggestion!
cc @david
Hi, guys,
sometimes, even when IN tells me to update, docker-compose won’t find any new files to pull. Right now I’m waiting to pull version 5.8.12 from 5.8.10.
Alright! I could pull an update right now.
