hi,
I am litle late about updating and I am asking if it safe to just click update
hi,
Since it’s updating through many releases it will likely require a lot of memory available.
If there are problem you can also manually copy over the latest release zip.
You mean a lot of memory on server ? I can manage hosting about that. What do you think what can be approx. number for handle that updating?
About manual copy, you mean I get the last version from zip and just uploaded to server and override ?
Updated before normaly
I suggest 1024MB
Yes that’s correct.
The last question.
Somewhere I find a version of PHP must be 8.0?
8.1 is also supported, and 8.2 should work.
I have on server one WP page and Theme are not supported.
So 7.4 works fine 8.0 not works
The latest version of the app requires at least PHP 8.0
Here I am
After update by FTP - last release files.
I get error for version of DB
Edit on hosting htacces file with
<FilesMatch “.(inc|php5|php4|php3|php2|php|phtml)$”>
SetHandler application/x-lsphp81
Get error:
Something is broken. Please let us know what you were doing when this error occurred. We will fix it as soon as possible. Sorry for any inconvenience caused.
What can I do next
It may help to run composer install
Sorry I am not friend with that. Can you just send me to write location
Another option is to copy over the latest release zip
It was done by that way. Last version uploaded trought FTP.
I will restore now and try over the app.
After I load the all file by FTP I get same error but design is different.
I think I have a client site. My logo on the left side and on the right side I have 500 error.
Are there details about the 500 error in storage/logs?
There are two web frontends, there are links to the demos here: https://invoiceninja.org
is there any solution to install fresh install and then migrate
It is possible to install fresh last version and export- import from old to new ?
You can use mysqldump to transfer the database, you’ll also want to copy over the .env file.
Is there some manuals for that transfer?
What about White labeling? In the past was worked fine but now I can not find that setup.
Sorry, we don’t have docs for this.
The white label is stored in the database so will be transferred along.
Thank you for your help.
What about for renew licence? First I must to do that. But I can not find
