We recommend using this shell script to automate the update process, run it as a daily cron to automatically keep your app up to date.
Base System Data: Debian 10.5, PHP 8.1, Apache/2.4.54 (Debian)
After Upgrade i got the following Error in laravel.log:
[2022-11-17 21:21:55] laravel.ERROR: During inheritance of ArrayAccess: Uncaught ErrorException: Return type of Illuminate\Support\Collection::offsetExists($key) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Support/Collection.php:1277
Stack trace:
#0 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Support/Collection.php(11): Illuminate\Foundation\Bootstrap\HandleExceptions->handleError()
#1 /var/www/invoiceninja/vendor/composer/ClassLoader.php(444): include('...')
#2 /var/www/invoiceninja/vendor/composer/ClassLoader.php(322): Composer\Autoload\includeFile()
#3 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Support/helpers.php(109): Composer\Autoload\ClassLoader->loadClass()
#4 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/PackageManifest.php(89): collect()
#5 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/PackageManifest.php(78): Illuminate\Foundation\PackageManifest->config()
#6 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/RegisterFacades.php(26): Illuminate\Foundation\PackageManifest->aliases()
#7 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(219): Illuminate\Foundation\Bootstrap\RegisterFacades->bootstrap()
#8 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(156): Illuminate\Foundation\Application->bootstrapWith()
#9 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(140): Illuminate\Foundation\Http\Kernel->bootstrap()
#10 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(110): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#11 /var/www/invoiceninja/public/index.php(53): Illuminate\Foundation\Http\Kernel->handle()
#12 {main} {"exception":"[object] (Symfony\\Component\\Debug\\Exception\\FatalErrorException(code: 1): During inheritance of ArrayAccess: Uncaught ErrorException: Return type of Illuminate\\Support\\Collection::offsetExists($key) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Support/Collection.php:1277
Stack trace:
#0 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Support/Collection.php(11): Illuminate\\Foundation\\Bootstrap\\HandleExceptions->handleError()
#2 /var/www/invoiceninja/vendor/composer/ClassLoader.php(322): Composer\\Autoload\\includeFile()
#3 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Support/helpers.php(109): Composer\\Autoload\\ClassLoader->loadClass()
#5 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/PackageManifest.php(78): Illuminate\\Foundation\\PackageManifest->config()
#6 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/RegisterFacades.php(26): Illuminate\\Foundation\\PackageManifest->aliases()
#7 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(219): Illuminate\\Foundation\\Bootstrap\\RegisterFacades->bootstrap()
#8 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(156): Illuminate\\Foundation\\Application->bootstrapWith()
#9 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(140): Illuminate\\Foundation\\Http\\Kernel->bootstrap()
#10 /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(110): Illuminate\\Foundation\\Http\\Kernel->sendRequestThroughRouter()
#11 /var/www/invoiceninja/public/index.php(53): Illuminate\\Foundation\\Http\\Kernel->handle()
#12 {main} at /var/www/invoiceninja/vendor/laravel/framework/src/Illuminate/Support/Collection.php:11)
Have anyone some suggestion how to complete migration?
fix .htaccess (complete files below) if you are on a subdomain
→ /var/www/path/to/invoiceninja/.htaccess
→ /var/www/path/to/invoiceninja/public/.htaccess
Ensure that Invoiceninja is working fine
Now the Update…
create a backup of the database
mysql db_invoiceninja < /var/www/path/to/db_invoiceninja.sql
update to latest version
→ cd /var/www/path/to/invoiceninja
→ git pull
→ git checkout v5-stable
→ composer install
→ php artisan ninja:post-update
correct files (only if you are on a subdomain like business.example.com)
<IfModule mod_rewrite.c>
# Redirect HTTP to HTTPS:
RewriteCond %{ENV:HTTPS} !=on
RewriteRule ^(.*) https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
# Make InvoiceNinja work in subdomains:
RewriteBase /
RewriteRule ^(.*)$ public/$1 [L]
RewriteRule "^.env" - [F,L]
# RewriteRule "^storage" - [F,L]
RewriteRule ^(.well-known)($|/) - [L]
</IfModule>
# https://github.com/h5bp/server-configs-apache/blob/master/dist/.htaccess
# # INTERNET EXPLORER #
# | Iframes cookies |
# Allow cookies to be set from iframes in Internet Explorer.
# https://msdn.microsoft.com/en-us/library/ms537343.aspx
# http://www.w3.org/TR/2000/CR-P3P-20001215/
<IfModule mod_headers.c>
Header set P3P "policyref=\"/w3c/p3p.xml\", CP=\"IDC DSP COR ADM DEVi TAIi PSA PSD IVAi IVDi CONi HIS OUR IND CNT\""
</IfModule>
# # MEDIA TYPES AND CHARACTER ENCODINGS #
# | Character encodings |
# Serve all resources labeled as `text/html` or `text/plain`
# with the media type `charset` parameter set to `UTF-8`.
# https://httpd.apache.org/docs/current/mod/core.html#adddefaultcharset
AddDefaultCharset utf-8
# Serve the following file types with the media type `charset`
# parameter set to `UTF-8`.
# https://httpd.apache.org/docs/current/mod/mod_mime.html#addcharset
<IfModule mod_mime.c>
AddCharset utf-8 .atom \
.bbaw \
.css \
.geojson \
.js \
.json \
.jsonld \
.manifest \
.rdf \
.rss \
.topojson \
.vtt \
.webapp \
.webmanifest \
.xloc \
.xml
</IfModule>
# # WEB PERFORMANCE #
# | Compression |
<IfModule mod_deflate.c>
# Force compression for mangled headers.
# https://developer.yahoo.com/blogs/ydn/pushing-beyond-gzipping-25601.html
<IfModule mod_setenvif.c>
SetEnvIfNoCase ^(Accept-EncodXng|X-cept-Encoding|X{15}|~{15}|-{15})$ ^((gzip|deflate)\s*,?\s*)+|[X~-]{4,13}$ HAVE_Accept-Encoding
RequestHeader append Accept-Encoding "gzip,deflate" env=HAVE_Accept-Encoding
</IfModule>
</IfModule>
# Map certain file types to the specified encoding type in order to
# make Apache serve them with the appropriate `Content-Encoding` HTTP
# response header (this will NOT make Apache compress them!).
# If the following file types wouldn't be served without the appropriate
# `Content-Enable` HTTP response header, client applications (e.g.:
# browsers) wouldn't know that they first need to uncompress the response,
# and thus, wouldn't be able to understand the content.
# http://httpd.apache.org/docs/current/mod/mod_mime.html#addencoding
AddEncoding gzip svgz
</IfModule>
# Compress all output labeled with one of the following media types.
# IMPORTANT: For Apache versions below 2.3.7 you don't need to enable
# `mod_filter` and can remove the `<IfModule mod_filter.c>` & `</IfModule>`
# lines as `AddOutputFilterByType` is still in the core directives.
AddOutputFilterByType DEFLATE "application/atom+xml" \
"application/javascript" \
"application/json" \
"application/ld+json" \
"application/manifest+json" \
"application/rdf+xml" \
"application/rss+xml" \
"application/schema+json" \
"application/vnd.geo+json" \
"application/vnd.ms-fontobject" \
"application/x-font-ttf" \
"application/x-web-app-manifest+json" \
"application/xhtml+xml" \
"application/xml" \
"font/opentype" \
"image/svg+xml" \
"image/x-icon" \
"text/cache-manifest" \
"text/css" \
"text/html" \
"text/javascript" \
"text/plain" \
"text/vtt" \
"text/x-component" \
"text/xml"
</IfModule>
</IfModule>
<IfModule mod_negotiation.c>
Options -MultiViews -Indexes
</IfModule>
RewriteEngine On
# Make InvoiceNinja work with subdomains:
# If you want to access InvoiceNinja via a subdomain and
# this rule is missing the browser will see a `500 internal server error`.
RewriteBase /
# Handle Authorization Header
RewriteCond %{HTTP:Authorization} .
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
# Redirect Trailing Slashes If Not A Folder...
RewriteCond %{REQUEST_URI} (.+)/$
RewriteRule ^ %1 [L,R=301]
# Handle Front Controller...
RewriteRule ^ index.php [L]
</IfModule>
# Blocks Search Engine Indexing
Header set X-Robots-Tag "noindex, nofollow"
# Prevents PDF File Caching
<FilesMatch ".pdf$">
Header set Cache-Control no-store
</FilesMatch>
</IfModule>
/var/www/path/to/invoiceninja/.env (excerpt)
APP_URL="https://business.example.com" //important: no slash at the end
BROADCAST_DRIVER=log
LOG_CHANNEL=stack
CACHE_DRIVER=file
QUEUE_CONNECTION=database
INTERNAL_QUEUE_ENABLED=false
SESSION_DRIVER=file
SESSION_LIFETIME=120
REQUIRE_HTTPS="true"
NINJA_ENVIRONMENT="selfhost"
#options - snappdf / phantom / hosted_ninja
PDF_GENERATOR=snappdf
UPDATE_SECRET=yoursecret
DELETE_PDF_DAYS=60
DELETE_BACKUP_DAYS=60
COMPOSER_AUTH='{"github-oauth": {"github.com": "${{ secrets.GITHUB_TOKEN }}"}}'
If this doesn’t work, I don’t know what else you could try. Maybe some others can help…
It looks like the shell script in the OP is also accessing the old download URL like I was. As mentioned the fact it silently redirects from a v5 version number to a v4 one is unintuitive, an error would be less confusing.
thats a nice workflow for update, your source is different from mine, cause my installation is based on the precompiled binary zip file, it looks like you sync your local branch und compile them.
The documention seems a little bit outdated.
I‘be got the system up and running, After zum troubleshooting.
Just do the post-Upgrade an everything seems fine.
Yes, I don’t download the zip… For me, the advantage is that I don’t have to worry about folder permissions, unzip zips and don’t have to copy files. However, I have already done the basic installation with Composer.
There would be another variant for you:
Run the update directly in the GUI and then do
