I make update and I got error, Error: app is already configured, backup then delete the .env file to re-run the setup, Please any body can help to fix the error, I ready disable env file, but no work , so any body can help,
Is it possible the database credentials in the .env file arenât correct?
Are there any details about the error in storage/logs/laravel-error.log?
Also if you are using Docker I found this GitHub issue that could help you out.
I had the same issue and hillel is right about the database credentials. storage/logs/laravel-error.log shows âAccess denied for user âninjaâ@âlocalhostââ after applying 4.5.46. Put single quotes around your password in the .env file and reboot.
DB_PASSWORD=âyourDBpasswordâ
