Unable to view client statement
Version ie <v5.10.30>
v5.10.40-C171
Zip
Describe the bug
Clicking View Statement on a client leads to a popup showing error 500
Logs show the following:
production.ERROR: Attempt to read property “EU” on array {“userId”:2,“exception”:"[object] (ErrorException(code: 0): Attempt to read property "EU" on array at /usr/share/nginx/invoiceninja/app/Utils/HtmlEngine.php:833)
I did just do an upgrade and then started having this issue,
I think the previous version I had was v5.10.20 or so
It seems like there were additional columns added in between updates and migrations weren’t run
I see there are a bunch of new migration files under database/migrations
Which ones would I have to run to fix this?
Thanks for all your help
Logs
[2024-10-17 11:44:01] production.ERROR: Attempt to read property “EU” on array {“userId”:2,“exception”:"[object] (ErrorException(code: 0): Attempt to read property "EU" on array at /usr/share/nginx/invoiceninja/app/Utils/HtmlEngine.php:833)
#0 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/HandleExceptions.php(256): Illuminate\Foundation\Bootstrap\HandleExceptions->handleError()
#1 /usr/share/nginx/invoiceninja/app/Utils/HtmlEngine.php(833): Illuminate\Foundation\Bootstrap\HandleExceptions->Illuminate\Foundation\Bootstrap\{closure}()
#2 /usr/share/nginx/invoiceninja/app/Utils/HtmlEngine.php(189): App\Utils\HtmlEngine->taxLabel()
#3 /usr/share/nginx/invoiceninja/app/Utils/HtmlEngine.php(880): App\Utils\HtmlEngine->buildEntityDataArray()
#4 /usr/share/nginx/invoiceninja/app/Services/Pdf/PdfService.php(147): App\Utils\HtmlEngine->generateLabelsAndValues()
#5 /usr/share/nginx/invoiceninja/app/Services/Pdf/PdfService.php(76): App\Services\Pdf\PdfService->init()
#6 /usr/share/nginx/invoiceninja/app/Http/Controllers/PreviewController.php(88): App\Services\Pdf\PdfService->boot()
#7 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\PreviewController->live()
#8 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(43): Illuminate\Routing\Controller->callAction()
#9 /usr/share/nginx/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php(21): Illuminate\Routing\ControllerDispatcher->dispatch()
#10 /usr/share/nginx/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingRoutingDispatcher.php(18): Sentry\Laravel\Tracing\Routing\TracingControllerDispatcherTracing->Sentry\Laravel\Tracing\Routing\{closure}()
#11 /usr/share/nginx/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php(20): Sentry\Laravel\Tracing\Routing\TracingRoutingDispatcher->wrapRouteDispatch()
#12 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Route.php(262): Sentry\Laravel\Tracing\Routing\TracingControllerDispatcherTracing->dispatch()
#13 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Route.php(208): Illuminate\Routing\Route->runController()
#14 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(808): Illuminate\Routing\Route->run()
#15 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(144): Illuminate\Routing\Router->Illuminate\Routing\{closure}()
#16 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(124): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#17 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(89): Illuminate\Routing\Middleware\ThrottleRequests->handleRequestUsingNamedLimiter()
#18 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Routing\Middleware\ThrottleRequests->handle()
#19 /usr/share/nginx/invoiceninja/app/Http/Middleware/QueryLogging.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#20 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\QueryLogging->handle()
#21 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(51): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#22 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Routing\Middleware\SubstituteBindings->handle()
#23 /usr/share/nginx/invoiceninja/app/Http/Middleware/Locale.php(95): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#24 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\Locale->handle()
#25 /usr/share/nginx/invoiceninja/app/Http/Middleware/TokenAuth.php(102): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#26 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\TokenAuth->handle()
#27 /usr/share/nginx/invoiceninja/app/Http/Middleware/SetDb.php(40): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#28 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\SetDb->handle()
#29 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(119): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#30 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(807): Illuminate\Pipeline\Pipeline->then()
#31 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(786): Illuminate\Routing\Router->runRouteWithinStack()
#32 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(750): Illuminate\Routing\Router->runRoute()
#33 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(739): Illuminate\Routing\Router->dispatchToRoute()
#34 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(201): Illuminate\Routing\Router->dispatch()
#35 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(144): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
#36 /usr/share/nginx/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/FlushEventsMiddleware.php(13): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#37 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\Laravel\Http\FlushEventsMiddleware->handle()
#38 /usr/share/nginx/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(45): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#39 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\Laravel\Http\SetRequestIpMiddleware->handle()
#40 /usr/share/nginx/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(31): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#41 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\Laravel\Http\SetRequestMiddleware->handle()
#42 /usr/share/nginx/invoiceninja/vendor/livewire/livewire/src/Features/SupportDisablingBackButtonCache/DisableBackButtonCacheMiddleware.php(19): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#43 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Livewire\Features\SupportDisablingBackButtonCache\DisableBackButtonCacheMiddleware->handle()
#44 /usr/share/nginx/invoiceninja/app/Http/Middleware/Cors.php(24): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#45 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\Cors->handle()
#46 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php(58): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#47 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Http\Middleware\TrustProxies->handle()
#48 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#49 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#50 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle()
#51 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#52 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(51): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#53 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Foundation\Http\Middleware\TrimStrings->handle()
#54 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#55 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Http\Middleware\ValidatePostSize->handle()
#56 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(110): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#57 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle()
#58 /usr/share/nginx/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Middleware.php(79): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#59 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\Laravel\Tracing\Middleware->handle()
#60 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(119): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#61 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(176): Illuminate\Pipeline\Pipeline->then()
#62 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(145): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#63 /usr/share/nginx/invoiceninja/public/index.php(56): Illuminate\Foundation\Http\Kernel->handle()
#64 {main}
It may help to run php artisan migrate
