Edit the description of a line item or task in the React interface and attempt to press enter. Nothing happens on mine or on the react demo site when attempted from multiple browsers. It does work on the demo.invoiceninja.co page.
Emails are sending from the react interface but nothing happens when I send one from the Linux desktop app. No errors logged. Didn’t try it on the demo sites.
The result is that I have to create and modify tasks/invoices using the Flutter desktop app and then swap to the web interface to send them out. Anyone had this happen? Tried multiple PCs, browsers and incognito modes with no luck.
I might have misspoken but react in Chrome sends invoices but I have to use the flutter desktop app to modify descriptions properly. Short term memory problems
You are correct, it does send from both methods. The queue must have been catching up which confused me. I was probably more frustrated by trying to type live notes into my task and jumping up and down on the enter button trying to get a new line. That appears to be a different issue which I put on Github.
I’m experimenting the exact same issue with Enter key in React UI.
It’s not working as of the latest IN update v5.11.6. I did try on desktop with Chrome and Firefox.
It’s working as expected though in the Flutter app, with IN mobile app and in my free https://app.invoicing.co/ account as well.
I don’t recall changing any settings lately. And I would suppose that doing so would impact Flutter and Mobile app !!!
