Hey,
I saw mention of twillio SMS feature in the past updates.
I wanted to know if we would be able to set up that feature on a self-hosted instance of Invoice Ninja. I can’t seem to be able to find any instructions anywhere.
The feature is currently used for 2FA backup but I’m assuming you want to use it to send invoices.
@david any thoughts?
Yes, Using them to send invoices would be amazing.
Also, How would I activate it for 2fa?
Our Twilio integration is specifically for 2FA recovery for our hosted application. It isn’t really required with self host where you have access to the Database.
I believe there is a feature request on github for SMS notification for invoices already.
Awesome!
I found the feature request on Github. I guess I’ll just keep an eye out there.
Thank you so much!
