Turning Off a Repeating Header
Hi all,
After much searching and troubleshooting via the existing forum threads (putting my business terms as html inside a “p” tag after the Totals table solved the apparently common issue of the Totals tables’ bad alignment, or issue with it moving pages), I cannot find a workaround to get the repeating header to play well with the “p” tag. My workaround so far is the awkward addition of a manual page break and then a few “br” tags to get the right padding for the new page of terms.
So, I’d like to “turn off” the repeating header when generating an invoice, but I can’t seem to do it. I’ve removed styling from the “header” and “footer” tabs and only the footer has disappeared. I even changed the class from “header” to my own in the Body tab, with its own styling, and still, the header is repeating on every page. Any advice?
Oy vey. Of course now I’m realizing that I’ve boxed myself in from being able to include the “terms” with a checkbox for the client… Isn’t there any way of formatting the Totals table and the terms properly?? Inspecting the elements suggests that there isn’t. It seems everything is lumped together under the same table div… But I suppose this is an issue for a different thread
If you’re using the hosted platform please send an email to [email protected] and we’ll try to help.
