So just installed the self-host version for testing as i found out there was an android app available. (But what’s the point of selecting self-host and adding the URL, if it’ll just show a blank one and not connect to the already selfhosted system.)
During setup in the last fase (after entering all info and pressing install) i was greeted with error 504. Tried refreshing the page and i was greeted with the login form. So install seems to have gone ok. At the bottom i noticed the red icon. It’s asking me to setup cron. My control panel is Plesk
Found 2 documentations so i don’t know which one is correct:
Free Source Available Invoicing, Expenses & Time-Tracking | Invoice Ninja and Configure — Invoice Ninja 4.5.37 documentation
I tried everything i can think off:
Task type: run a command
Command: /usr/local/bin/php /subdomain.domain.tld/artisan ninja:send-invoices
Run: daily at 8am
Result: Fail with “-: /usr/local/bin/php: No such file or directory”
change path to
: /opt/plesk/php/7.4/bin/php: No such file or directory
Change to “run a php script”
Script path: /opt/plesk/php/7.4/bin/php/subdomain.domain.tld/artisan ninja:send-invoices
Error: Could not open input file: /opt/plesk/php/7.4/bin/phpsubdomain.domain.tld/artisan ninja:send-invoices
The only thing that “works” is simply setting the script path to subdomain.domain.tld/artisan. If i add “ninja:send-invoices” to “with arguments” the command fails too.
Command “ninja:send-invoices” is not defined.
Did you mean one of these?
ninja:check-data
ninja:check-db
ninja:create-account
ninja:create-single-account
ninja:create-test-data
ninja:demo-mode …
What the hell am i doing wrong?
