Hello !
Where can I help improve translation ? I see French is not complete
All I can do to help the project is this as I have no knowledge on dev, but I don’t know where and how to provide the missing translations…
Matthieu
Hello !
Matthieu
I’m just doing that for Slovenian language.
Is there a way to DL texts.php from transifex directly to try it on invoice ninja?
Thank you
Br,
Dali
Thanks, I’ve asked to be on French and am waiting for approval
Regards
Matthieu
I would, but how to get this file from Transifex?
Br.
Dali
Ahh, yes.
Thank you!
I will try to finish it all in next few days.
Thank you
Br,
Dali
Matthiew.
I did that while ago. Just couldn’t find the link to download from within translation console. It’a bit hidden
Everything is OK. Thank you for your help!
Br,
Dali
Ok sorry
Have Fun translating !!!
Hi Hillel.
In order to get it working I needed to:
For Language I needed to create:
Create Database Entry
Add additional fields in text.php
‘lang_Slovenian’ => ‘Slovenian’,
Hi Hillel.
Will this be included in next release. I plan to get translation complete shortly.
Thank you
Br,
Dali
If the translation is complete we’ll include it with our next release in a few days.
Note: the language ids shown in the screenshot are different than the ids I see in my table.
I included Slovenian language while ago. Maybe some updates where adding languages afterwards therefore different IDS.
Should there be any concern for this?
Happy to help with Spanish if needed.
