I’m using the self-host version of InvoiceNinja and i’m wondering if its possible to translate the Invoice Terms and Footer based on the client’s language.
I’m a PHP programmer myself, so i could alter some code to make this happen, but i don’t want to go editing the core right away. Updating InvoiceNinja would be a pain in the ass afterwards.
Since you’re already using i18n, can i modify a language file and add my own translation for the Terms and Footer?
We’re talking about different things
I meant the Terms and Footer on the client’s invoice.
The one’s you can configure in Settings > Invoice Settings > Default Messages > Invoice Terms (or on the create invoice / recurring page itself).
I tried configuring the terms as “texts.default_terms” and added “default_terms” to the translation file, but it doesn’t seem that this is run through trans(). I’m not familiar with Laravel and the routing system, so i’m doing trial-and-error for now, but not very efficient.
If i want to run the terms through trans(), where should i do this?
