Hello; I was posting on Github but thought I should put this one here: When saving or clicking “Email Invoice” I get the message “There was an error saving your invoice Forbidden”
I am logged in as owner.
No errors in laravel error log file
No erros in apache
Latest version 2.9.3 (prepackaged )
I’ve checked the user account settings and can’t find the reason for this error
Does this happen when both saving a new invoice and updating an existing invoice?
The only time it does not happen is when “save draft” is clicked for new invoice. I will try making new invoice and make first click “email invoice” or other
Also, can you check is_admin is true for your user in the users table in the database.
I had the same issue. It turned out that the upgrade to php 7.1 caused this. I previously used php 7.0.
So if you use 7.1 downgrading to 7.0 may solve this.
I was using an even older PHP version and upgraded to 7.0.
Any other suggestions I could try? I’m stumped. Could it have something to do with https vs http ? I recently switched it over to secured site so I could look into getting payment gateways set up.
Can you provide more details. Did this just start happening or did you recently upgrade? If you upgraded from which version, and are you using a new server or the same one?
This error happened with version 2.9.3 (I believe it was a fresh install.) I created a new sub-directory and created a certificate for it (https://subdir.example.com/) When the error occured one thing I tried was to change it back to http but this did not change the Error.
No change in server otherwise, still my shared hosting on Funio.com
I’m going to create another install from scratch and see if it happens again. I may be the cause of it with all the mucking around. I will use v. 2.9.3 and no encrypted web.
A fresh install did not have any errors while saving the invoice.
I think the error was created when I changed the subdirectory name during an upgrade. .Htaccess? .ENV file? not sure. I combined too many thing into one step.
I’m now running php 7.0 with the latest version 2.9.5 and NO ISSUES! saving/emailing/deleting (I invoiced Thor-Son-Of-Oden but he never paid Haha
Okay, this time it’s a new install version 2.9.5. I’m tempted to give full access to anyone since I don’t even have any “real data” into the application yet. I just finished setting up paypal and wanted to test the results with a mock invoice and got the error again.
I have something more to report: If I turn off “Live Preview” under /settings/account_management then No error message when I click “Email Invoice” but no Email sent. I am able to Save Invoice without error.
With live preview ON, I cannot save or email invoice due to error.
Should the Laravel debug bar show something under the EMAIL tab when I click “email invoice”?
I am starting to wonder if my shared host is blocking something or I’m missing a PHP module.
The page uses an AJAX call so you may not see the page request, you can check the network tab in the browser debug console to see if a request is being made.
The word ‘Forbidden’ is what’s shown when the permission checks fail. It would also explain why nothing is appearing in the logs. That said, you’re an admin so it shouldn’t fail.
