Template: Split notes
in the notes of a product I have different lines, each line begins with a dash (‘-’). In my template for the invoice I would like to generate in the product table different list items from the notes by using the split function in twig as follows:
<td>
   <p>{{ item.product_key }}</p>
   <ul>
      {% set temp_notes = item.notes|split('-') %}
      {% for note in temp_notes %}
         <li> {{ note }} </li>
      {% endfor %}
   </ul>
</td>
But for some reason the split function does not work. It seems like
returns nothing. The dash ist not the problem. I also tried different characters to seperat.I also tried
{% set temp_notes = item.notes|split('') %}
which should result in a separation after every character. But again the split returns nothing.
Any ideas or hints?
The split function isn’t currently enabled.
Are you using the hosted or selfhosted app?
Hi Hillel, sorry. I am in the wrong section. I have the hosted version - Entreprise plan.
I will open the ticket in the right section.
If you’re using the hosted version I suggest sending an email to [email protected]
