I’ve installed and gotten Invoice Ninja installed with the React App and purchased the white label option. I’ve successfully added my Postmark for emails and Square for Payments. Going through setting everything up and got to Tax Rates.
I live in New Jersey and our sales tax rate is 6.625% and I cannot enter this in the Tax Rate field. It only accepts up to 2 decimal places. This needs to be updated in some way. You can enter any crazy number as long as it doesn’t have more than 2 decimals.
Not sure if this is a limit on the front-end field or back-end. If it’s just on the front end I’m okay with manual adjusting the database to get the correct value in if that’ll do the trick.
