Hi there, my first post so forgive any slights.
I’m hosted and using version 5.0.138.0 per the microsoft store.
Issue, when trying to create a new task catagory if the color select option is seleceted the entire screeen for the app just goes white. I can get out of it by hitting “esc” and I can force a color by typing a hex code in but if it goes to select a color from the color wheel it just blanks the app out.
edit the title because it was terrible
