In my system log on the dashboard it is only showing until August 10th. Nothing after that. How do I fix this?
@david any thoughts to debug this?
Most likely your queues have stopped running so the system logs are no longer processing.
from the command like you could run
php artisan queue:listen
I am experiencing the same issue. Email logs from August 10th (possibly earlier) until now are not displayed in the system log on hosted v5.
How do I do that? I’m not very good with the behind the scenes computer stuff
I believe we only send email errors to the system logs.
