I’m trying to add Mollie as a payment gateway. On the website I see it should be supported but I can’t find it in the list when adding a new gateway.
I’ve archived my current gateway (Stripe) to be sure but that doesn’t help.
I went back to the hosted v4 and when I remove Stripe there, I’m able to add Mollie.
Is the Mollie integration just a work in progress due to the v5 migration?
If so, can I keep using the v4 until v5 supports Mollie and then run the data migration process again? I did that already so not sure wether that’s going to create duplicates or something.
