Hi there,
I would like to see the option to specify which clients can pay using credit card and which ones can’t.
Thanks!
Mahesh
Hi there,
Thanks!
Mahesh
Thanks for the suggestion, we’ll keep it in mind.
If the amounts are the issue maybe you could set a max limit for CC payments.
One workaround would be to create two separate companies, one with the CC enabled and one without.
This is the kind of functionality you’d find on an ecommerce platform.
