can i have a hint how to style the $view_button in the outgoing mails
Sven
Sven
@david can you please advise?
thanks i must search for the right way to insert that it`s long ago
okay it`s to long ago i need another hint where i can insert the css, update save
You can actually inject this into the body of your email template something like this will work:
.new_button { background-color:red !important; }hi david i need further help… ist this correct or is there a way to set it globaly like custom.css file
you should be able to use this in your template
.new_button { background-color:red !important; }Supported by Invoice Ninja and Event Schedule
