Help please.
Recently, my self-hosted v5,12,26 installation has started showing a number of ‘Pending Jobs’ next to the orange triangle, that appear to go up every few days (basically after jobs get created).
Failed jobs are at zero, though, these are just increasing ‘pending jobs’
Running the CLI commands for flushing or clearing the queue only returns that there are no jobs to clear or to flush.
I’ve checked file permissions, and they are all correct (or at least appear to be).
Checking caravel logs, this is the only error that appears to stand out:
[2025-05-03 04:38:16] production.ERROR: SQLSTATE[HY000] [2002] No such file or directory {“exception”:"[object] (PDOException(code: 2002): SQLSTATE[HY000] [2002] No such file or directory>
----> WHAT FILE OR DIRECTORY is it referring to that it can’t fine? That’s the part I can’t figure out.
#0 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Connectors/Connector.php(66): PDO->__construct()
#1 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Connectors/Connector.php(85): Illuminate\Database\Connectors\Connector->createPdoCon>
#2 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Connectors/Connector.php(48): Illuminate\Database\Connectors\Connector->tryAgainIfCa>
#3 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Connectors/MySqlConnector.php(24): Illuminate\Database\Connectors\Connector->createC>
#4 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Connectors/ConnectionFactory.php(185): Illuminate\Database\Connectors\MySqlConnector>
#5 [internal function]: Illuminate\Database\Connectors\ConnectionFactory->Illuminate\Database\Connectors\{closure}()
#6 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Connection.php(1231): call_user_func()
#7 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Concerns/ManagesTransactions.php(187): Illuminate\Database\Connection->getPdo()
#8 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Concerns/ManagesTransactions.php(153): Illuminate\Database\Connection->handleBeginTra>
#9 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Concerns/ManagesTransactions.php(127): Illuminate\Database\Connection->createTransact>
#10 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Database/Concerns/ManagesTransactions.php(26): Illuminate\Database\Connection->beginTransacti>
#11 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Queue/DatabaseQueue.php(226): Illuminate\Database\Connection->transaction()
#12 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(351): Illuminate\Queue\DatabaseQueue->pop()
#13 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(366): Illuminate\Queue\Worker->Illuminate\Queue\{closure}()
#14 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(164): Illuminate\Queue\Worker->getNextJob()
#15 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Queue/Console/WorkCommand.php(149): Illuminate\Queue\Worker->daemon()
#16 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Queue/Console/WorkCommand.php(132): Illuminate\Queue\Console\WorkCommand->runWorker()
#17 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): Illuminate\Queue\Console\WorkCommand->handle()
#18 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/Util.php(43): Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
#19 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(95): Illuminate\Container\Util::unwrapIfClosure()
#20 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(35): Illuminate\Container\BoundMethod::callBoundMethod()
#21 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/Container.php(696): Illuminate\Container\BoundMethod::call()
#22 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Console/Command.php(213): Illuminate\Container\Container->call()
#23 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/symfony/console/Command/Command.php(279): Illuminate\Console\Command->execute()
#24 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Console/Command.php(182): Symfony\Component\Console\Command\Command->run()
#25 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/symfony/console/Application.php(1094): Illuminate\Console\Command->run()
#26 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/symfony/console/Application.php(342): Symfony\Component\Console\Application->doRunCommand()
#27 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/symfony/console/Application.php(193): Symfony\Component\Console\Application->doRun()
#28 /var/www/billing.pacbill.me/htdocs/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(198): Symfony\Component\Console\Application->run()
#29 /var/www/billing.pacbill.me/htdocs/invoiceninja/artisan(35): Illuminate\Foundation\Console\Kernel->handle()
#30 {main}
