Receiving an Internal 500 error when the stripe webhook is used to try and post successful payment. It seems like the rest of the installation is working correctly. I’m on version v5.5.5-C88
Error in Larvel.log:
[2022-08-01 14:23:29] production.ERROR: Function () does not exist {“exception”:"[object] (ReflectionException(code: 0): Function () does not exist at /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Routing/RouteSignatureParameters.php:27)
Just to update this, I ran the follow commands:
composer update
composer install
artisan optimize
Everything ran successfully. API in Stripe is also the latest. Still isn’t working.
Does anyone have any ideas on what is causing this? I saw a few issues with webhooks and 500 errors on github that were resolved but nothing related to this.
I tried downloading the ZIP as a “Clean” install and it’s doing the same thing.
full log if it helps:
[2022-08-03 01:20:25] production.ERROR: Function () does not exist {“exception”:"[object] (ReflectionException(code: 0): Function () does not exist at /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Routing/RouteSignatureParameters.php:27)
#0 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Routing/RouteSignatureParameters.php(27): ReflectionFunction->__construct(’’)
#1 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Routing/Route.php(527): Illuminate\Routing\RouteSignatureParameters::fromAction(Array, Array)
#2 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Routing/ImplicitRouteBinding.php(78): Illuminate\Routing\Route->signatureParameters(Array)
#3 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Routing/ImplicitRouteBinding.php(28): Illuminate\Routing\ImplicitRouteBinding::resolveBackedEnumsForRoute(Object(Illuminate\Routing\Route), Array)
#4 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Routing/Router.php(874): Illuminate\Routing\ImplicitRouteBinding::resolveForRoute(Object(Illuminate\Foundation\Application), Object(Illuminate\Routing\Route))
#5 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(41): Illuminate\Routing\Router->substituteImplicitBindings(Object(Illuminate\Routing\Route))
#6 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Routing\Middleware\SubstituteBindings->handle(Object(Illuminate\Http\Request), Object(Closure))
#7 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#8 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Routing/Router.php(726): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#9 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Routing/Router.php(703): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request))
#10 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Routing/Router.php(667): Illuminate\Routing\Router->runRoute(Object(Illuminate\Http\Request), Object(Illuminate\Routing\Route))
#11 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Routing/Router.php(656): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request))
#12 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(167): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request))
#13 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request))
#14 /home/USER/public_html/billing/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(45): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#15 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Sentry\Laravel\Http\SetRequestIpMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure))
#16 /home/USER/public_html/billing/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(42): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#17 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Sentry\Laravel\Http\SetRequestMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure))
#18 /home/USER/public_html/billing/vendor/livewire/livewire/src/DisableBrowserCache.php(19): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#19 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Livewire\DisableBrowserCache->handle(Object(Illuminate\Http\Request), Object(Closure))
#20 /home/USER/public_html/billing/vendor/beyondcode/laravel-query-detector/src/QueryDetectorMiddleware.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#21 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): BeyondCode\QueryDetector\QueryDetectorMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure))
#22 /home/USER/public_html/billing/vendor/barryvdh/laravel-debugbar/src/Middleware/InjectDebugbar.php(59): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#23 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Barryvdh\Debugbar\Middleware\InjectDebugbar->handle(Object(Illuminate\Http\Request), Object(Closure))
#24 /home/USER/public_html/billing/app/Http/Middleware/Cors.php(25): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#25 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\Cors->handle(Object(Illuminate\Http\Request), Object(Closure))
#26 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#27 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Http\Middleware\TrustProxies->handle(Object(Illuminate\Http\Request), Object(Closure))
#28 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#29 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#30 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle(Object(Illuminate\Http\Request), Object(Closure))
#31 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#32 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#33 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\TrimStrings->handle(Object(Illuminate\Http\Request), Object(Closure))
#34 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#35 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle(Object(Illuminate\Http\Request), Object(Closure))
#36 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#37 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle(Object(Illuminate\Http\Request), Object(Closure))
#38 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#39 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(142): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#40 /home/USER/public_html/billing/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(111): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request))
#41 /home/USER/public_html/billing/public/index.php(57): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request))
#42 {main}
It appears v5.4.12 does NOT have this bug.
david
August 3, 2022, 3:40am
8
I have tagged a new release which should resolve this.
Thank you, David! I appreciate the help.
EDIT: I can confirm 5.5.6-C89 solved the issue.
