Primarily, whenever I try to Import Customers, i get a “500: Server Error”. The nginx error log shows:
“2022/08/31 09:53:53 [error] 767#767: 18 FastCGI sent in stderr: “PHP message: Stripe Notice: Undefined property of Stripe\Customer instance: sources” while reading response header from upstream, client: ...*, server: *****.com, request: “POST /api/v1/stripe/import_customers? HTTP/2.0”, upstream: “fastcgi://unix:/run/php/php7.4-fpm.sock:”, host: .com", referrer: "https://.com/”
Secondarily, we are confused about where to enter customers. Do we enter them into invoice ninja first and then import? Or stripe first and then import? Or enter in both and then Verify? Verify seems to work but it shows 2 customers in Stripe and 1 in ninja. The 1 that is in both seemed (I think, that’s my best recollection as I’ve been tinkering for days with this) to have imported from Stripe but, as noted, that import no longer works. I successfully made a credit card payment by the one customer (me as a test) that is in both Stripe and Ninja.
I’ll also note that if i click on System Logs at Gateway Stripe, the wheel just spins and spins.
Thank you. I’m not super familiar with browser console but in firefox, i get
Unchecked lastError value: Error: Could not establish connection. Receiving end does not exist. background.js:1
I tried to import and the next log entry was at line 1458:
[2022-09-01 15:50:13] production.ERROR: Trying to get property ‘data’ of non-object {“userId”:1,“exception”:"[object] (ErrorException(code: 0): Trying to get property ‘data’ of non-object at /var/www/html/invoice-ninja/app/PaymentDrivers/Stripe/UpdatePaymentMethods.php:81)
Quick update that we’re finally able to create customers in Ninja and accept payments from those customers. Still get 500 error on import and the spinning wheel on Stripe System Logs.
[2022-09-19 19:03:30] production.ERROR: property_exists(): Argument #1 ($object_or_class) must be of type object|string, null given {“userId”:1,“exception”:"[object] (TypeError(code: 0): property_exists(): Argument #1 ($object_or_class) must be of type object|string, null given at /var/www/html/invoice-ninja/app/PaymentDrivers/Stripe/UpdatePaymentMethods.php:77)
I am having these same issues on the hosted version. But in my case, when I connect Stripe it ask me to log in, then after it says that Stripe is good to go and to “Click Here” to continue. At this point it says that access was denied… When I look in Invoice Ninja the Stripe integration is there but I get 500 error when trying to import customers. When I look at events in Stripe’s console, it says that Invoice Ninja was authorized each time I try this.
Also, how do I decide which customer I bill through Sripe and which customers I bill through WePay if both are active?
Finally, what is the purpose of importing customers? I already have all my customers in Invoice Ninja so I guess I’m confused about the purpose of the import feature.
