I would like to know if invoice ninja support auto invoicing from Stripe ?
The scenario is a payment is made on stripe (by API), i would like to generate an invoice reflecting this payment in invoice ninja, that will be automatically sended to the customer.
Is it possible ? If it is possible how to configure and does it work with test data in Stripe ?
You’d want to make sure ‘Token Billing’ is set to Always on /settings/online_payments. If you’re using the API you can add ?auto_bill=true to charge the client’s card on file.
Thanks for your answer, but it doesn’t work. You did’nt answer to the last part of my question does it work with test data in stripe ?
When you say if you use the API you mean invoice ninja API ? so i don’t understand because what i want is that a stripe payment triggers an invoice in invoice Ninja. Can you reconsider my question ?
