I’m having Invoice Ninja on a self hosted environment with CPanel and installed via Softaculous.
When I check the Health APP I can see the following. So all cron task are working.
So First all there is still Phanton JS Web as PDF While in my env file there is
So when I check or want to send an invoice I still get the error
500: There was an error generating the PDF with Phantom JS
But it should be the other one. I also tried already to change the env file and put it on Phantom and PHANTOMJS_PDF_GENERATION=true but the message stays the same. In Version 4 I don’t have this issue.
Also send email is not working but maybe this is due to the PDF error
And I just see that my env file is saying QUEUE_CONNECTION=database but the Queue is still on sync
In the laravel log I have
[2021-12-29 18:48:37] production.ERROR: There was an error generating the PDF with Phantom JS {“exception”:"[object] (App\Exceptions\PhantomPDFFailure(code: 0): There was an error generating the PDF with Phantom JS at /home//app/Utils/PhantomJS/Phantom.php:150)
I had a problem with postscript generation if the image files (logo) etc were not available after an upgrade. Usually this shows up in log files. Admittedly I’m using white label version so have ninja hosted PDF creation not phantom but it is worth checking the log files for something like this [2021-12-28 17:11:51] production.ERROR: file_get_contents(https://facturatie.servitweb.be/public/storage/76alNMIDOPei96wipCBWVzCB5KC8XRXX/WY8X1e0UFB5zVu6GxFdFaN1Jcfcp9LAe42UVjx9w.png): failed to open stream: HTTP request failed! HTTP/1.0 404 Not Found
Please note I have modified the base URL above from a real error and URL in my log to reflect your setup. including adding ‘public’ back in as I have hardened my install to prevent access to app files. This issue occurs if you have uploaded any sort of company logo to use on invoices.
