Hi.
Invoices will show as paid (Invoice template) even if not.
$status_logo
v5.5.81-C108
Br,
Dali
Hi.
$status_logo
v5.5.81-C108
Br,
Dali
@david any ideas?
Are you using a custom design?
The only other possibility is your base designs have not updated.
php artisan ninja:design
We have added in the follow to the .is-paid class to control whether it is shown or not
.is-paid {
color: #D23;
border: 1rem double #D23;
transform: rotate(-5deg);
font-size: 6rem;
font-family: "Open sans", Helvetica, Arial, sans-serif;
border-radius: 0;
padding: 0.5rem;
opacity: 0.2;
z-index:200 !important;
position: fixed;
display: $show_paid_stamp;
Hm, yes I have custom design.
But it doesn’t seem to be working even for built templates (Plain, Clean, Bold) as changing template within invoice itself.
However removing line display: $show_paid_stamp; will show it but it will show on all invoices, not just paid ones. Is there any other setting to enable this anywhere?
Thank you
Br,
Dali
I’m not sure. We use a filter which toggles the paid stamp only if the entity is paid and the show_paid_stamp setting is turned on:
$data['$show_paid_stamp'] = ['value' => $this->entity->status_id == 4 && $this->settings?->show_paid_stamp ? 'flex' : 'none', 'label' => ''];
The fact that is is showing all the time indicates that the css is return true all the time. Have you tried running
It’s working now, but it’s not there on View PDF and Download PDF…?
Is this by design?
Br,
Dali
