Statement showing wrong logo and client
Version ie <v5.10.60> white labeled
Environment softaculous install
Checklist
  • Can you replicate the issue on our v5 demo site https://demo.invoiceninja.com or Invoice Ninja? no
  • Have you searched existing issues? yes
  • Have you inspected the logs in storage/logs/laravel.log for any errors? yes
Describe the bug
I have installed via softaculous, I run invoices for my 3 businesses i imported the data from previous install using json for each company, all data seems to be present on new system. when creating new invoices everything loads correctly but when i open a customer and view statement for the customer the wrong client name is listed and also the wrong logo but with the correct customer data. the client that gets listed on the statement is always the same client and the logo is always the same.
Steps To Reproduce
This happens on all customers in all companies
I believe this issue is corrected in the latest release.
Ok I will update to the next release and re check, Thanks
Can the install be updated directly or do I need to wait for Softaculous to release an update ? Thanks
You should be able to manually copy over the latest release.
