I’m encountering an issue where client statements are being generated with incorrect client names. Despite the accuracy of the financial data, the same client name is appearing on all statements, irrespective of the intended recipient. This problem persists even when generating statements directly from the client portal.
I believe this is corrected in the latest release.
i’m using v5.10.60-M172
i installed it using softaculous is there a way to update it manually? as the new version is not on softaculous yet
You could setup a clean install and then copy over the database using mysqldump as well as the .env file.
