Split Terms and Public notes to dedicated pages
I assume the parts are out of order.
We can add an import/export option to the designs in the next release, it will make it easier to help figure out the problem.
@david any thoughts?
Hi @davsch
This is how I solved it:
In the Content Tab (below the closing div from id=body)
<div class="page-break" contenteditable="false"></div>
<div id="public-notes">
    $public_notes
</div>
In the includes Tab
/* Defines a class for manual page breaks via inserted .page-break element */
div.page-break {
    page-break-after: always;
/* Define the styling of the div container which holds the public notes */
#public-notes {
    margin-top: 2cm;
In the Footer Tab
<div class="repeating-footerx" id="footer">
    <p data-ref="total_table-footer">$entity_footer</p>
    <script>
        // Clear up space a bit…
    </script>
</div>
Maybe this helps you…
Seems like latest updates broke this code and it no longer works. Any ideas on how to make it work again?
Need more information to be helpful.
Hi
I just updated my Invoice Ninja to 5.8.50. In my Installation, the code works fine as before. Means, that the Swiss QR Code ist always separate on the last page. What exactly work no longer in your setting?
Found the issue, if I don’t have the anything in public notes - code dosen’t work… :slight_smile:
