"Something Went Wrong
Version ie <v5.13.18>
Environment
Checklist
  • Have you searched existing issues?
    • Nothing helped resolve
  • Have you inspected the logs in storage/logs/laravel.log for any errors?
    *Attached below
Describe the bug
“Something went wrong” error when upgrading past v5.13.4 (i.e. v5.13.18)
Steps To Reproduce
Upgrade past v5.13.4 to v5.13.18
Additional context
Hi All,
Hoping one of you might be able to point me in the right direction with an error I’m getting at the moment after upgrading to anything above v5.13.4.
Upgrade goes Ok, and all data appears to be there but I get a message saying “Something went wrong” at the top of the screen for a few seconds that comes and goes.
Cheers,
Adam
Details of my setup are below:
Docker Desktop Version 4.69.0 (224084)
Containers nginx:latest invoiceninja/invoiceninja:5 mysql:5
Working Invoice Ninja v5.13.4
Not working Invoice Ninja v5.13.18
Health Check
SystemEmail: smtpQueue: databasePDF: SnapPDF PDF Generator
Database ConnectionPassed
PHPweb: 8.2.28cli: PHP 8.2.28 (cli) (built: Mar 14 2025 00:18:46) (NTS)Memory: 512MAPI: 5.13.18
Screenshots
Logs
[2026-04-19 11:09:17] production.ERROR: SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '(ORDER BY date) as total,
date
FROM (
’ at line 2 (Connection: mysql, Host: db, Port: 3306, Database: ninja, SQL:
SELECT
SUM(monthly_total) OVER (ORDER BY date) as total,
date
FROM (
SELECT
sum(invoices.balance) as monthly_total,
LAST_DAY(invoices.date) as date
FROM clients
JOIN invoices
ON invoices.client_id = clients.id
AND invoices.status_id IN (2,3)
AND invoices.company_id = :company_id
AND clients.is_deleted = 0
AND invoices.is_deleted = 0
AND (invoices.date BETWEEN :start_date AND :end_date)
AND IFNULL(CAST(JSON_UNQUOTE(JSON_EXTRACT(clients.settings, ‘$.currency_id’)) AS SIGNED), :company_currency) = :currency_id
GROUP BY LAST_DAY(invoices.date)
) monthly_totals
) {“userId”:1,“exception”:"[object] (Illuminate\Database\QueryException(code: 42000): SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '(ORDER BY date) as total,
date
FROM (
SELECT
date
FROM (
SELECT
FROM clients
JOIN invoices
) monthly_totals
) at /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Connection.php:838)
#0 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Connection.php(794): Illuminate\Database\Connection->runQueryCallback()
#1 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Connection.php(411): Illuminate\Database\Connection->run()
#2 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/DatabaseManager.php(491): Illuminate\Database\Connection->select()
#3 /var/www/app/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(363): Illuminate\Database\DatabaseManager->__call()
#4 /var/www/app/app/Services/Chart/ChartQueries.php(506): Illuminate\Support\Facades\Facade::__callStatic()
#5 /var/www/app/app/Services/Chart/ChartService.php(88): App\Services\Chart\ChartService->getOutstandingChartQuery()
#6 /var/www/app/app/Http/Controllers/ChartController.php(77): App\Services\Chart\ChartService->chart_summary()
#7 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\ChartController->chart_summaryV2()
#8 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(43): Illuminate\Routing\Controller->callAction()
#9 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php(21): Illuminate\Routing\ControllerDispatcher->dispatch()
#10 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingRoutingDispatcher.php(18): Sentry\Laravel\Tracing\Routing\TracingControllerDispatcherTracing->Sentry\Laravel\Tracing\Routing\{closure}()
#11 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php(20): Sentry\Laravel\Tracing\Routing\TracingRoutingDispatcher->wrapRouteDispatch()
#12 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Route.php(265): Sentry\Laravel\Tracing\Routing\TracingControllerDispatcherTracing->dispatch()
#13 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Route.php(211): Illuminate\Routing\Route->runController()
#14 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(822): Illuminate\Routing\Route->run()
#15 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Routing\Router->Illuminate\Routing\{closure}()
#16 /var/www/app/app/Http/Middleware/ValidJson.php(51): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#17 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): App\Http\Middleware\ValidJson->handle()
#18 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(126): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#19 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(90): Illuminate\Routing\Middleware\ThrottleRequests->handleRequestUsingNamedLimiter()
#20 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Illuminate\Routing\Middleware\ThrottleRequests->handle()
#21 /var/www/app/app/Http/Middleware/QueryLogging.php(40): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#22 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): App\Http\Middleware\QueryLogging->handle()
#23 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#24 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Illuminate\Routing\Middleware\SubstituteBindings->handle()
#25 /var/www/app/app/Http/Middleware/Locale.php(95): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#26 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): App\Http\Middleware\Locale->handle()
#27 /var/www/app/app/Http/Middleware/TokenAuth.php(105): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#28 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): App\Http\Middleware\TokenAuth->handle()
#29 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(137): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#30 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(821): Illuminate\Pipeline\Pipeline->then()
#31 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(800): Illuminate\Routing\Router->runRouteWithinStack()
#32 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(764): Illuminate\Routing\Router->runRoute()
#33 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(753): Illuminate\Routing\Router->dispatchToRoute()
#34 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(200): Illuminate\Routing\Router->dispatch()
#35 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
#36 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/FlushEventsMiddleware.php(13): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#37 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Sentry\Laravel\Http\FlushEventsMiddleware->handle()
#38 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(45): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#39 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Sentry\Laravel\Http\SetRequestIpMiddleware->handle()
#40 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(31): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#41 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Sentry\Laravel\Http\SetRequestMiddleware->handle()
#42 /var/www/app/vendor/livewire/livewire/src/Features/SupportDisablingBackButtonCache/DisableBackButtonCacheMiddleware.php(19): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#43 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Livewire\Features\SupportDisablingBackButtonCache\DisableBackButtonCacheMiddleware->handle()
#44 /var/www/app/app/Http/Middleware/Cors.php(24): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#45 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): App\Http\Middleware\Cors->handle()
#46 /var/www/app/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php(58): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#47 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Illuminate\Http\Middleware\TrustProxies->handle()
#48 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#49 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#50 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle()
#51 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#52 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(51): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#53 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Illuminate\Foundation\Http\Middleware\TrimStrings->handle()
#54 /var/www/app/vendor/laravel/framework/src/Illuminate/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#55 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Illuminate\Http\Middleware\ValidatePostSize->handle()
#56 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(109): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#57 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle()
#58 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Middleware.php(79): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#59 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Sentry\Laravel\Tracing\Middleware->handle()
#60 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(137): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#61 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(175): Illuminate\Pipeline\Pipeline->then()
#62 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(144): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#63 /var/www/app/public/index.php(56): Illuminate\Foundation\Http\Kernel->handle()
#64 {main}
[previous exception] [object] (PDOException(code: 42000): SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '(ORDER BY date) as total,
date
FROM (
’ at line 2 at /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Connection.php:420)
#0 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Connection.php(420): PDO->prepare()
#1 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Connection.php(827): Illuminate\Database\Connection->Illuminate\Database\{closure}()
#2 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Connection.php(794): Illuminate\Database\Connection->runQueryCallback()
#3 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Connection.php(411): Illuminate\Database\Connection->run()
#4 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/DatabaseManager.php(491): Illuminate\Database\Connection->select()
#5 /var/www/app/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(363): Illuminate\Database\DatabaseManager->__call()
#6 /var/www/app/app/Services/Chart/ChartQueries.php(506): Illuminate\Support\Facades\Facade::__callStatic()
#7 /var/www/app/app/Services/Chart/ChartService.php(88): App\Services\Chart\ChartService->getOutstandingChartQuery()
#8 /var/www/app/app/Http/Controllers/ChartController.php(77): App\Services\Chart\ChartService->chart_summary()
#9 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\ChartController->chart_summaryV2()
#10 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(43): Illuminate\Routing\Controller->callAction()
#11 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php(21): Illuminate\Routing\ControllerDispatcher->dispatch()
#12 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingRoutingDispatcher.php(18): Sentry\Laravel\Tracing\Routing\TracingControllerDispatcherTracing->Sentry\Laravel\Tracing\Routing\{closure}()
#13 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php(20): Sentry\Laravel\Tracing\Routing\TracingRoutingDispatcher->wrapRouteDispatch()
#14 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Route.php(265): Sentry\Laravel\Tracing\Routing\TracingControllerDispatcherTracing->dispatch()
#15 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Route.php(211): Illuminate\Routing\Route->runController()
#16 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(822): Illuminate\Routing\Route->run()
#17 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Routing\Router->Illuminate\Routing\{closure}()
#18 /var/www/app/app/Http/Middleware/ValidJson.php(51): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#19 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): App\Http\Middleware\ValidJson->handle()
#20 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(126): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#21 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(90): Illuminate\Routing\Middleware\ThrottleRequests->handleRequestUsingNamedLimiter()
#22 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Illuminate\Routing\Middleware\ThrottleRequests->handle()
#23 /var/www/app/app/Http/Middleware/QueryLogging.php(40): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#24 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): App\Http\Middleware\QueryLogging->handle()
#25 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#26 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Illuminate\Routing\Middleware\SubstituteBindings->handle()
#27 /var/www/app/app/Http/Middleware/Locale.php(95): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#28 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): App\Http\Middleware\Locale->handle()
#29 /var/www/app/app/Http/Middleware/TokenAuth.php(105): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#30 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): App\Http\Middleware\TokenAuth->handle()
#31 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(137): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#32 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(821): Illuminate\Pipeline\Pipeline->then()
#33 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(800): Illuminate\Routing\Router->runRouteWithinStack()
#34 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(764): Illuminate\Routing\Router->runRoute()
#35 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(753): Illuminate\Routing\Router->dispatchToRoute()
#36 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(200): Illuminate\Routing\Router->dispatch()
#37 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
#38 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/FlushEventsMiddleware.php(13): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#39 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Sentry\Laravel\Http\FlushEventsMiddleware->handle()
#40 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(45): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#41 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Sentry\Laravel\Http\SetRequestIpMiddleware->handle()
#42 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(31): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#43 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Sentry\Laravel\Http\SetRequestMiddleware->handle()
#44 /var/www/app/vendor/livewire/livewire/src/Features/SupportDisablingBackButtonCache/DisableBackButtonCacheMiddleware.php(19): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#45 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Livewire\Features\SupportDisablingBackButtonCache\DisableBackButtonCacheMiddleware->handle()
#46 /var/www/app/app/Http/Middleware/Cors.php(24): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#47 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): App\Http\Middleware\Cors->handle()
#48 /var/www/app/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php(58): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#49 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Illuminate\Http\Middleware\TrustProxies->handle()
#50 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#51 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#52 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle()
#53 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#54 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(51): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#55 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Illuminate\Foundation\Http\Middleware\TrimStrings->handle()
#56 /var/www/app/vendor/laravel/framework/src/Illuminate/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#57 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Illuminate\Http\Middleware\ValidatePostSize->handle()
#58 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(109): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#59 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle()
#60 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Middleware.php(79): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#61 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(219): Sentry\Laravel\Tracing\Middleware->handle()
#62 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(137): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#63 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(175): Illuminate\Pipeline\Pipeline->then()
#64 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(144): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#65 /var/www/app/public/index.php(56): Illuminate\Foundation\Http\Kernel->handle()
#66 {main}
This may be the same issue:
I have a similar issue after updating to 5.13.22…
https://github.com/invoiceninja/invoiceninja/releases/download/v5.13.22/invoiceninja.tar
[2026-05-14 16:55:38] production.INFO: Copied file from URL
[2026-05-14 16:55:38] production.INFO: Finished copying
[2026-05-14 16:55:38] production.INFO: Extracting tar
[2026-05-14 16:57:26] production.INFO: Finished extracting files
[2026-05-14 16:57:26] production.INFO: Deleted release zip file
[2026-05-14 16:57:26] production.INFO: Removing cache files
Here’s my log file. No errors shown.
However when I try to login and give it the id/pw - it tells me SOMETHING WENT WRONG and further down the screen SERVER ERROR.
Help!
