After editing the columns on an invoice in the settings menu non of my invoices are display and im getting a “something went wrong” popup?
I reverted to the old UI using
as suggested by hillel in another post and that solved the issue
You should be able to remove columns without the app breaking, feel free to create an issue on GitHub.
