"something went wrong" and logged out
Version <v5.10.48>
A strange one.
  1. i can login OK
  2. when i try and make any POST changes and click save i get an error message of “something went wrong” and i am logged out. This seems to happen when i try to save any changes.
  3. My hosting tech support DO NOT have this problem, and all works as it should when they try doing the exact same
I have tried 4 browsers, clearing cache/data, incognito mode, using a VPN to change my IP.
No error is logged in invoice ninja.
I am running windows 10 pro, standard windows firewall, Avira free AV.
The issue must me local, but what i don’t know.
All my software is up to date
This problem is recent, after no major updates.
Any ideas why this would work on 1 pc/network, and not another.
Jon
Are you using the web app or the desktop app?
Are there any related errors in storage/logs?
the web app i think. i use the url of accounts.example.com in my browser.
(where do i find the desktop app>).
no error_log file at all in storage/logs.
  • when i run the health check, all comes back as OK.
also didnt state, as probably obvious, i tried rebooting the PC and network
I can login, view anything, i just cant save anything without the error message…
The desktop app can be downloaded here:
Only console log error is onloading the page of:
“Uncaught SyntaxError: Unexpected token ‘<’ (at plugin.min.js:1:1)”,
but the page loads fine.
The error message of “something went wrong” flashes up then i am almost instantly redirected to the login page.
PS i will install and try the desktop app, and report back
Thanks!!!
You may want to post an issue on GitHub for the problem with the web app.
when i try the desktop app, i get a 403 error when i try and save anything, but i can login OK
Any ideas as 403 is of course a permissions/forbidden error.
This is probably the reason in the desktop app too, but why 1 pc/network gets this error yet others dont… hmmm
Not sure i should post it as a GIT issue just yet, as it seems to be a local issue
PS. i am in a differnt time zone to the server but changing my PC to match the time zone makes no difference
I suggest trying the “End all sessions” option in the desktop app on Settings > Device Settings
done, and same error 403
do you want me to message you my login details?
Please do NOT send your credentials
Are there any details in the web server error logs?
Only
[13-Nov-2024 17:08:50 UTC] PHP Fatal error: Uncaught Error: Class "ComposerAutoloaderInit95e7******768ecfbc78582cd" not found in /home//public_html/vendor/autoload.php:25
But only 2 of these errors, and i have tried many more than 2 times to save changes
Also wrong server time for the “errors”
it must be a local error to me.
for some reason it seems to log me out (incorrect session token or something) when i try and save anything, although i can browse all the admin, just not make any changes (although others logging in with the same credentials can make changes…).
It is a really strange issue…
Is the time correct on the server?
let me check, should be though
yes correct UK server time of “13-11-2024 18:41:56”
(i am in Spain though, so + 1 hour for me)
I believe the server should be set to UTC time
yes it is, current server time is 13-11-2024 18:53:13
Ok, I suggest creating a discussion on GitHub to follow up
