Hi
I’m using the latest v5.10.13.
I installed the snappdf dependencies and then installed using vendor/bin/snappdf download which installed the ‘ungoogled’ version.
When I run a test via the command line it works fine:
./vendor/bin/snappdf convert --html "Hello world" test.pdf
Success! PDF saved at test.pdf
But when I update .env to PDF_GENERATOR=snappdf and then run php artisan optimize and then try to view an invoice it comes up with:
production.ERROR: Unable to generate the raw PDF {"userId":267,"exception":"[object] (App\\Exceptions\\FilePermissionsFailure(code: 0): Unable to generate the raw PDF at /home/runcloud/webapps/invoiceninja/app/Jobs/Entity/CreateRawPdf.php:116)
I’ve run the ownership and file permissions commands, tried creating /home/webuser/tmp/Crashpad and chmod +x on /chrome-linux/chrome_crashpad_handler but still no luck.
Any ideas much appreciated.
