Is there a detailed setup guide on installing snappdf locally on an ubuntu install? Not too familiar with composer and the linked documentation assumes some prior knowledge
Hi any update on this?
Keen to get this working so that I can fully migrate from V4
For anyone with the same issue, follow the install instructions for ubuntu on the SnapPDF github, install all the requirements and then run the composer command in the root of your invoiceninja install directory.
You will then need to rerun the chown command to set the permissions to www-data
