Had a tough time getting SnapPDF Generation 100% on CentOS 8 and hoping this may help someone running into the same issues because this is what got it working well for me.
I got close to getting snappdf working following the official instructions but a few things were strange, like in the I.N client portal the invoices were mirrored (even though in the I.N app doing a preview they were fine)
This is what got PDF Generation 100% for me on CentOS 8.3:
sudo dnf install -y atk aspell cups-libs libdrm libXcomposite libXdamage libXrandr libgbm libnss3.so libnssutil3.so libsmime3.so libnspr4.so libXext.so.6 libXfixes.so.3 libcairo.so.2 libgdk_pixbuf-2.0.so.0 alsa-lib libxshmfence gtk3
change directory to path of your I.N install
sudo ./vendor/bin/snappdf download
sudo -u nginx php artisan optimize
Background:
After you run âsudo ./vendor/bin/snappdf downloadâ from I.N install directory, run ldd to find missing dependencies:
âsudo ldd ./vendor/beganovich/snappdf/versions/839879-Linux_x64/chrome-linux/chrome | grep notâ (or whatever version was downloaded, this was the version for me at time of this writing)
I get that your suppose to be able to run composer to install missing libraries âcomposer require beganovich/snappdfâ. But this didnât actually work for me. It said it worked. However comparing before and after using ldd it didnât resolve any of the missing dependencies and they were still ânot foundâ
Trying to DNF install the missing library names mentioned using ldd did not work. Going to https://pkgs.org/ and searching for the missing library names, finding the x86_64 rpm for cent os 8 and scrolling down to the âInstall howtoâ showed me the right package names that worked for me.
