Hi.
When I go to heath check is says SnapPDF not enabled.
If I change .env from
PDF_GENERATOR=hosted_ninja to PDF_GENERATOR=snappdf
it will fail to generate pdfs.
What to do?
Thank you
Br,
Dali
Hi.
What to do?
Thank you
Br,
Dali
Which PDF rendered do you see listed above in the health check dialog?
There was a bug in the previous release which caused the âSnapPDF not enabledâ message to be shown even if it was enabled.
With .env setting PDF_GENERATOR=hosted_ninja
With .env setting PDF_GENERATOR=snappdf
Are there any errors in storage/logs?
The one that works for me is PDF_GENERATOR=hosted_ninja
snappdf will have a green check but fails to render PDFs.
What are benefits of using a snappdf over hosted_ninja?
Br,
Dali
If you use hosted_ninja the PDF is generated on our servers, if you use snappdf itâs generated on your server
Makes sense, yes.
Indeed I will go for snappdf. Will check logs a bit later.
Thank you
Br,
Dali
Here is invoiceninja.log.
Error Output:
/var/www/invoiceninja/vendor/beganovich/snappdf/versions/1032348-Linux_x64/chrome-linux/chrome: error while loading s
hared libraries: libatk-1.0.so.0: cannot open shared object file: No such file or directory[2022-08-09 09:59:02] production.INFO: The command ââ/var/www/invoiceninja/vendor/beganovich/snappdf/versions/1032348
-Linux_x64/chrome-linux/chromeâ ââheadlessâ ââdisable-gpuâ ââdisable-translateâ ââdisable-extensionsâ ââdisable-
syncâ ââdisable-background-networkingâ ââdisable-software-rasterizerâ ââdisable-default-appsâ ââdisable-dev-shm-u
sageâ ââsafebrowsing-disable-auto-updateâ âârun-all-compositor-stages-before-drawâ ââno-first-runâ ââno-marginsâ
ââno-sandboxâ ââprint-to-pdf-no-headerâ ââhide-scrollbarsâ ââignore-certificate-errorsâ ââprint-to-pdf=/tmp/pdf_
k2bPLc.pdfâ â/tmp/html_El18Nc.htmlââ failed.Exit Code: 127(Command not found)
Working directory: /var/www/invoiceninja/public
Output:
Error Output:
hared libraries: libatk-1.0.so.0: cannot open shared object file: No such file or directory[2022-08-09 10:00:01] production.INFO: Sending recurring invoices 2022-08-09 10:00:01
[2022-08-09 10:00:01] production.INFO: 2022-08-09 Sending Recurring Invoices. Count = 0
[2022-08-09 10:00:02] production.INFO: Sending invoice reminders 2022-08-09 10:00:02
[2022-08-09 11:00:01] production.INFO: Sending recurring invoices 2022-08-09 11:00:01
[2022-08-09 11:00:01] production.INFO: 2022-08-09 Sending Recurring Invoices. Count = 0
[2022-08-09 11:00:01] production.INFO: Sending invoice reminders 2022-08-09 11:00:01
Maybe this will help:
Yes, that did the trick.
sudo apt install libnss3-dev libatk1.0-0 libatk-bridge2.0-0 libcups2 libgbm1 libpangocairo-1.0-0 libgtk-3-0
Thank you so much!!!
Br,
Dali
