Version 5.11.28
Ubuntu 24.04 self hosted
Have been unable to generate a PDF since installation. Using the hosted version as an example, when an invoice is created, it can be viewed in the lower pane of the screen and also printed. While attempting to do this same thing in our self-hosted, only a blank screen shows. If I try to just print the pdf, a red error flag is displayed. I followed a couple earlier posts & installed what was termed as necessary dependencies but did not seem to help.
Laravel log:
[2025-01-22 20:33:29] production.ERROR: The command “‘/var/www/invoiceninja/vendor/beganovich/snappdf/versions/ungoogled/chrome-linux/chrome’ ‘–headless’ ‘–disable-gpu’ ‘–disable-translate’ ‘–disable-extensions’ ‘–disable-sync’ ‘–disable-background-networking’ ‘–disable-software-rasterizer’ ‘–disable-default-apps’ ‘–disable-dev-shm-usage’ ‘–safebrowsing-disable-auto-update’ ‘–run-all-compositor-stages-before-draw’ ‘–no-first-run’ ‘–no-margins’ ‘–no-sandbox’ ‘–print-to-pdf-no-header’ ‘–no-pdf-header-footer’ ‘–hide-scrollbars’ ‘–ignore-certificate-errors’ ‘–print-to-pdf=/tmp/pdf_QjN2xw.pdf’ ‘/tmp/html_ylJmIF.html’” failed.
Exit Code: 127(Command not found)
Working directory: /var/www/invoiceninja/public
Output:
Error Output:
/var/www/invoiceninja/vendor/beganovich/snappdf/versions/ungoogled/chrome-linux/chrome: error while loading shared libraries: libatk-1.0.so.0: cannot open shared object file: No such file or directory
{“userId”:1,“exception”:"[object] (Exception(code: 0): The command "‘/var/www/invoiceninja/vendor/beganovich/snappdf/versions/ungoogled/chrome-linux/chrome’ ‘–headless’ ‘–disable-gpu’ ‘–disable-translate’ ‘–disable-extensions’ ‘–disable-sync’ ‘–disable-background-networking’ ‘–disable-software-rasterizer’ ‘–disable-default-apps’ ‘–disable-dev-shm-usage’ ‘–safebrowsing-disable-auto-update’ ‘–run-all-compositor-stages-before-draw’ ‘–no-first-run’ ‘–no-margins’ ‘–no-sandbox’ ‘–print-to-pdf-no-header’ ‘–no-pdf-header-footer’ ‘–hide-scrollbars’ ‘–ignore-certificate-errors’ ‘–print-to-pdf=/tmp/pdf_QjN2xw.pdf’ ‘/tmp/html_ylJmIF.html’" failed.
