Since update text.small_company_info on invoice
i updated last week to latest version from 5.10.x and i now have the following placeholder on my invoices: text.small_company_info
It is applied after $tax_info in my invoice template. When i remove $tax_info then this placeholder is also not shown. But i need $tax_info.
When i search on github then it seems to have to do with the definition of “small company” where no taxes are applied. But i never changed my company info to that.
Can someone tell me where i can define that i am no small company? Because i can not find it.
Thank you, best regards, Andreas
I suggest asking in a discussion on GitHub.
I did that here: Since last update text.small_company_info on invoice · invoiceninja/invoiceninja · Discussion #10555 · GitHub
Unfortunately it is not solved - so if somebody has a hint if this placeholder “text.small_company_info” is a text field somewhere in the Invoiceninja Backend. That would be great. I can not find it. And i have this placeholder text now on every draft invoice and can not send it.
Just to know where to post what in the future: Is github now the place instead of the forum?
We use the support forum to provide support for existing features, if you find a bug or want to request a feature we use GitHub.
I believe a fix has been checked in:
Thank you very much. There was no issue linked to i have not seen that. :slight_smile:
