I would like to have a signature at the botton of the invoice with the word “Issued” and an image with my signature below.
It would be a simple thing like:
Issued
<Signature image>
I tried to do that by customizing the invoices, but i don’t actually know how to do it.
Anyone can help ?
You should be able to add it using a base64 encoded image.
You can see examples on the ‘Images’ tab here:
http://pdfmake.org/playground.html
I try to do it like pdfmake.org examples in the footer area, but i keep getting errors.
http://nimb.ws/fHLxQa
The image needs to be base64 encoded.
If you’d like help from a developer you can submit a request here:
https://www.thedevelopers.ro/customisation-request-invoiceninja/
I can’t afford to pay 200 Euro minimum for this customization, so i was hoping to find some help here.
Well, even if i delete the image section and i try to enter some simple text like “Issued” according to the pdfmake.org it should be some code like
“columns”: [
“text”: “$invoiceFooter”,
“alignment”: “left”
‘Issued’
But i still get error message. What am I doing wrong ?
if i enter
text: ‘Issued’
I still get an error message “Bad string”
Try using double quotes (") instead of single quotes (’)
It worked !!
And then to enter the image below the “Issued” i use the code
"Issued",
image: "data....."
But everything dissapeads after that from the bottom of the page.
May 21, 2017, 8:05am
11
Progress… not sure why the rest would disappear though.
Issue solved.
Thank you so much for your help.
I really appreciate it.
